Need 700R4 help
Old May 16, 2010 | 11:35 PM
GetMeSome's Avatar
Car: 87 Camaro
Axle/Gears: 270
Need 700R4 help
I purchase an 87 Camaro with a 700R4. It used be a 2.8V6 in it from what i was told. The problem I have is that on the tailshaft, there is no place to screw the speedo cable into....the even bigger issue is that I dont have a bracket that mounts to the tranny that the Shifter Cable connects to. I am in search and need of this bracket. The guy I purchased the car from told me that some weird looking bracket was the right one...but when I climbed under my friends 92 and looked at his 700R4 it looks more like a Z shaped bracket that is used. One last thing...I dont see any spot to mount the Torque bar to the tail of the tranny either...seems like I might need some sort of adapter plate or something.
Any suggestions or ideas?
Old May 19, 2010 | 10:20 AM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
Re: Need 700R4 help
It sounds like the trans was from a donor car and not a camaro. The tailshaft is f-body specific for the torque arm mounting points. Are you talking about the bracket that attaches to the shifter shaft and connects to the shift cable?
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
