Swapping from auto to manual; pedal questions??
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
I am going to be swapping to a manual transmission soon and am curious; I just bought a set of manual 3rdgen pedals and will be refinishing them today. I have 3 switches on them - 2 are pressed by the brake pedal arm and one is pressed by the clutch arm. Is there anything else on the pedal assembly that I need or am I set? Does it bolt in direct place of the auto brake pedal assembly?
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: Swapping from auto to manual; pedal questions??
Thats all you need. Of course you will need the clutch master and you will have to do some wiring. And basically they bolt right in place of the brake pedal. You have to drill the holes for the support bars on the cluch pedal and cut the hole for the master, then they bolt right in place.
1992 Trans Am
May 10, 2023 07:19 PM
