NEED T56 HELP!!!!
Old May 19, 2010 | 07:26 PM
85ws6's Avatar
Car: 91 T/A
Engine: 350 TPI w/bolt ons
NEED T56 HELP!!!!
Hey guys. I just finished my T56 swap into my 91 T/A and when I started it the whole car shakes bad. It's like a drive train vibration but not sure what would be causing it. It is vibrating with or without the clutch pedal depressed. Trans went in smooth and had no problems (should have know by how easy it was going together I would have problems) and torqued all the bolts, flywheel and pressure plate to spec. The clutch is a resurfaced centerforce with a stock LT1 flywheel that is also resurfaced, could that be an issue if it was not done properly? Any suggestions would be appreciated or if anyone has had this issue please help me out! I did try the search option but found nothing related to my issue. Thanks in advance.
Old May 19, 2010 | 07:48 PM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
Re: NEED T56 HELP!!!!
is your motor stock sounds like a flywheel balancing problem
Old May 19, 2010 | 08:14 PM
85ws6's Avatar
Car: 91 T/A
yea stock 305, one piece RMS.
Old May 21, 2010 | 10:40 AM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
I have to agree we did that once in a mustang (neutral ballanced flywheel) and had the same car shaking problems your experiencing, then we swaped in the stock flywheel and it went away.
I was doing a little research on this, looks like the stock LT1 flywheel has a counterweight which is approx 125g, maybe your flywheel is 180* out or something.
Old May 21, 2010 | 11:28 AM
85ws6's Avatar
Car: 91 T/A
Checked the flywheel last night and the counter weight is not there. Just picked up a new to me flywheel and will install it tonight. I am sure that this is my problem but will let you guys know for sure. Thanks to everyone who replied in this matter.
Old May 21, 2010 | 11:59 AM
Tony89GTA's Avatar
Car: 89 GTA
Here is a pic showing the LT1 flywheel backside with the counter weight to give you a idea what your missing.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bigjay89gta
Oct 15, 2015 08:04 AM
meeklay812
Oct 1, 2015 03:46 PM
Vincent135
Sep 28, 2015 10:50 PM
