Just Rebuilt 4L60E, has no Overdrive... Help!!!
Car: 1990 Firebird
Engine: 6.0L LQ4
Transmission: 4L60E 4000 Stall
Axle/Gears: 3.23 G80 (01 TA)
I just rebuilt my 4L60E transmission to handle the power of my engine. I have it installed and have 1,2,3 and reverse but I have no overdrive.
I didn't have TCC as well but its because I didn't properly wire it up. I have no DTC's when I use HP tuners.
What could cause me to lose 4th gear only?
Re: Just Rebuilt 4L60E, has no Overdrive... Help!!!
I have the same problem. I stopped at Advanced to have the codes checked and he said it was one of the throttle position sensors. I checked my ATSG manual and it lists the TPS as a possible cause as well as the fluid pressure switch assy, brake pedal switch and the 2-4 band assy assembled improperly. I'm going to try the TPS first. I realize this is an old post, did you figure out the cause in your case? If so, what was it? Maybe you can help me... Thanks in advance.
KO1
16
Oct 15, 2015 05:00 PM
