Shifter or Transmission problem?
Old May 24, 2010 | 07:04 PM
Boogie123's Avatar
Car: 88 Camaro
Transmission: Th350
Axle/Gears: 3.73's
The last two times I went WOT from gear 2-3, it hasn't actually went into 3rd. Instead, it just revs like it's in neutral. Also, sometimes when I put it in park and let off the break, the car will start rolling and I'll have to move the shifter in and out of park until it actually goes into park. Anybody got any idea what's going on here? It sounds like something that would happen if the shifter cable wasn't short enough or something, I really don't know what to look for to fix this problem.
Old May 24, 2010 | 07:26 PM
JTNKTZ's Avatar
Car: 1991 Camaro RS/1989 Vert RS
Engine: 355/350
Transmission: T-5/T-5
Axle/Gears: BW9bolt3.45posi/3.23 Posi
Re: Shifter or Transmission problem?
wot 2-3 is a sign that the 3-4 clutch pack is going out. I have had 2 trannys do that to me...
The not stayin in park is definitely the cable.
Old May 25, 2010 | 06:21 PM
Boogie123's Avatar
Car: 88 Camaro
Transmission: Th350
Axle/Gears: 3.73's
Damn, supposedly the tranny was freshly rebuilt. So what the hell could I do to fix the park issue? Is a worn cable common?
jhawkeye
May 25, 2022 06:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
BlackphantomZ28
Apr 24, 2016 08:14 AM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
Dialed_In
Aug 20, 2015 01:45 PM
