5 speed auto
Old May 24, 2010 | 07:33 PM
cooljo39's Avatar
Car: 86 T/A
Engine: 305 TPI and 355 TPI in progress
Transmission: TH700R4 w/Trans pack and vette serv
5 speed auto
I guys, I own my 86 Trans am for a year now, I was happy cause I thought i got an TH700R4. My friend as a 86 T/A too but he have the carb version. I take a ride in his T/A and on highway at 60 mph the engine was running at around 2000 RPM, I found that wierd cause mine's running at 1600 RPM. Last night I was driving with friend and for the first time I counted how many time the tranny shift and it as 5 speeds.... Anyone know what's sitting under my shifter?
Old May 24, 2010 | 07:36 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: 5 speed auto
its the 700r4, and its a 4 speed with overdrive. thats why there are 5 "shifts" your friends trans may not be working correctly, or it may have different rear axle gears than yours, giving the extra rpm's
Old May 24, 2010 | 07:58 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 5 speed auto
It's the Torque Converter locking up - at 60mph that will easily make a 300-400RPM difference. Your friend's car is not locking the torque converter - is it a factory carb setup (a computer-controlled Quadrajet) or is it aftermarket carb (like a Holley or Edelbrock)? If it's aftermarket, chances are the swap was done without making any provision for the TC to lock.
Old May 24, 2010 | 08:32 PM
cooljo39's Avatar
Car: 86 T/A
Re: 5 speed auto
Ok, I thought the 700R4 was a 3 speed + an overdrive. Thank you guys!
Old May 24, 2010 | 08:38 PM
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
Re: 5 speed auto
false.
shift 1, 1-2
shift 2, 2-3
shift 3, 3-4
"shift" 4, lockup kicks in
Old May 24, 2010 | 08:42 PM
cooljo39's Avatar
Car: 86 T/A
Re: 5 speed auto
I tried it manually, I put in the first gear, then I push the shifter to the second gear and when I put it in drive it goes on the third gear, but the tranny shift a fourth time in drive. And when i put it on the overdrive it shift again. Strange?
Old May 24, 2010 | 08:49 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: 5 speed auto
Originally Posted by RED_DRAGON_85
false.
shift 1, 1-2
shift 2, 2-3
shift 3, 3-4
fine mr. technicality,
it has 5 "speeds" of forward travel 1 2 3 4 od
Old May 24, 2010 | 08:50 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: 5 speed auto
no thats normal, 4 speeds then OD. "D" is drive, not 3rd, so it will shift to 4th in "D"
Old May 24, 2010 | 10:04 PM
Car: 85 Camaro IROC
Engine: 5.7 TPI
Re: 5 speed auto
no.
im not trying to be rude, but im wondering when the last time you drove a car with a 700r4 was.
a 700r4 has 4 and exactly 4 speeds.
1st gear
2nd gear
3rd gear
and 4th gear, which also happens to be an overdrive gear.
overdrive is simply defined as a gear where the output is faster than the input as opposed to the first 3 where the output speed is less than or equal to the input speed.
a lockup torque converter in theory can give you somewhat of a different gear, but its not really another gear ratio unless there is no slip, which is impossible to achieve with a regular torque converter.
its entirely possible that you have a 5 speed auto, but highly unlikely
Old May 25, 2010 | 01:21 PM
cooljo39's Avatar
Car: 86 T/A
Re: 5 speed auto
Is there a casting number or something like that I could find too identify that tranny?
The oil pan is rectangular and around 12 inch front to rear and 10 inch from side to side
Old May 25, 2010 | 02:54 PM
87350IROC's Avatar
Car: 87' IROC
Re: 5 speed auto
What RED_DRAGON is saying is correct.
You probably just have a 700r4 and are confusing the torque convertor lockup with a shift to a 5th gear. Find a picture of a 700r4 fluid pan on google and compare it to what you have.
Old May 25, 2010 | 06:30 PM
Car: 85 Camaro IROC
Engine: 5.7 TPI
Re: 5 speed auto
look at the pan, google is your friend.
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
nugentcj
Camaros Wanted
Dec 22, 2015 02:58 PM
IROCtometal
Sep 9, 2015 10:01 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
