driveshaft loop...?
Car: 1990 camaro rs
Engine: 305 tbi
driveshaft loop...?
So I took my camaro to the tracks on street tires the other day and didnt do to bad but I want to use slicks and my friend said I could borrow his because there perfect size he says, W.E. I need a driveshaft loop and I cant find any do people make them or am I stuck on my own? If you have a link to one please post it.
thanks Tim
thanks Tim
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: driveshaft loop...?
Mine was $30 shipped off brand off eBay. Little hesitate to get it but it was 1/4" steel or so all one piece nice welds and fit floor contours great.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Lakewood makes a third gen specific loop designed to fit the contours of the third gen floor. To install it, you need to pull out the seats and carpet to drill through the floor and install the mounting bolts.
The other option is to buy an aftermarket torque arm. They come with a driveshaft loop installed on the new tranny crossmember.
The new torque arm costs a lot more than just the simple driveshaft loop but it's also a lot easier to install and is much better for the car than the factory stamped steel torque arm.
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
i use the lakewood one its easy once the rugs and seats are out and you only have to pull the rug half way back and it's cheap compared to the others that are mounted on the crossmembers unless your looking to upgrade that too Thread
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
topteam54
Oct 6, 2015 12:21 AM
1989, 3rd, 91, bar, camaro, crossmember, drive, driveshaft, gen, install, loop, make, roll, shaft, transmission
