T5 Transmissinon Electronic Speed Senor Gear
Old May 26, 2010 | 10:21 AM
jcon104's Avatar
Ok this is what i got....i got a 1991 z/28 camaro. The car had a 305 TPI with a 700 R4 trans. I pulled the motor and trans out becasue i bought a new 350 and T5 trans. I bolted the TPI on top of the 350 and the engine is great. The trans bolted right up and the car runs great. My only problem is the speed sensor. I can not find a electronic speed sensor gear for this trans. I bought the speed sensor from GM and I have that bolted in the trans where it needs to go just to keep the trans fluid from coming out. I need the gear that goes on the back of the speed sensor that interlocks with the gears in the trans. Can someone help me out with this. It is a basic 700r4 to W.C. T5 swap. If someone could tell me what to do i would appreciate it. Because right now I am driving the car and i have no idea how fast im going or how many miles im putting on the car, that is why i am not driving it much. Once I get this right gear, my check engine light will go off and i can finally set my idel to wear it needs to be. Right now the car is running a little rich because it doesnt no how fast its going....someone please let me know if you have anything.
thanks
Old May 26, 2010 | 10:24 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: T5 Transmissinon Electronic Speed Senor Gear
Originally Posted by jcon104
[B]I can not find a electronic speed sensor gear for this trans. I bought the speed sensor from GM and I have that bolted in the trans where it needs to go just to keep the trans fluid from coming out. I need the gear that goes on the back of the speed sensor that interlocks with the gears in the trans. Can someone help me out with this.
Try the following company for the part:
http://www.transmissioncenter.net/sp...n_______va.htm
JamesC
Old May 27, 2010 | 12:33 PM
jcon104's Avatar
Re: T5 Transmissinon Electronic Speed Sensor Gear
i tried that website. i need the gear that goes on the back of the Electronic VSS. i have 3.73 rears in the car that just got put it. i junked the 2.73 and now all i need is the gear for the VSS so i can finish my car. Can someone please let me know if you have anything...thanks
IROCZDAVE (88-L98)
Aug 24, 2015 06:54 AM
InfinityShade
Aug 22, 2015 08:00 PM
jbd1969
Aug 17, 2015 07:06 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
