Need help with 700R4
Old May 30, 2010 | 09:52 AM
madmax87's Avatar
Hey guys,
Need help with this problem. No real experience with auto's. I've read a lot of threads but I may have 2 different problems going on here. 1st, 87 IROC with a 305 TPI and 700R4. Just got the car on road. Previous owner installed a shift kit. Car goes 1st-3rd no problem. Never goes into OD. When I pull shifter into 1st, it acts like its in 2nd.
Ok I can see if the linkage is not setup correctly it may not go into 1st but since OD is right after neutral, shouldn't it still go into OD? Does this sound like a TV cable adj or bad clutches?
Thanks as usual....
Old May 30, 2010 | 10:23 AM
1Broke_camaro's Avatar
Car: 1992 Chevy Camaro
Engine: 350 TBi in the working
Transmission: 700R4 :(
Re: Need help with 700R4
look on the trans driver side. and right about the pan and shift linkage there should be a connector. as dumb as it sounds make sure its plugged in. im in search of some MAJOR trans help to lol
Old May 30, 2010 | 01:17 PM
madmax87's Avatar
Will do, thanks!
Old May 30, 2010 | 08:02 PM
madmax87's Avatar
Plug is connected. Don't see anyway to adjust shifter cable. Read on forum that they stretch and just need to be replaced. Pulled old one out and waiting for part to come in.
Old May 30, 2010 | 08:31 PM
duckmanquacker's Avatar
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
sounds like the previous owner didnt do the shift kit correctly. if he forgot some of the check ***** then you wont have fourth.
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
