Speedo gear question.
Old May 30, 2010 | 03:55 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
I'm trying to work out what speedo gears I'm needing for 3.42 gears with a stock IROC wheel with 245/50/16s on them. I can't find the tire height anywhere.
Does anyone know the height, or indeed what gears are needed?
Cheers.
Old Jun 2, 2010 | 11:45 PM
americanmuscle3's Avatar
Car: 83 z28
Re: Speedo gear question.
if its the stock tire its 26"
Old Jun 3, 2010 | 12:17 AM
87tpiz28's Avatar
Car: 1987 z28
Engine: 305tpi
Axle/Gears: 2.73 posi
just did a 342 swap. you need a 15tooth drive and a 40 tooth driven.
15tooth is a gray gear 40tooth is a black gear. part numbers are in the stickys (drivetrain section) the 40 tooth driven needs the larger speedo housing. should be about 99.8% accurate, meaning it will read a hair (.2%) fast but if you step up to a 41 driven you will read much slower (-.3%)
Old Jun 7, 2010 | 03:30 AM
mayhamfx's Avatar
http://www.rimsntires.com/rt_specs.j...&text1=&text2=
Old Jun 15, 2010 | 09:35 AM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Thank you gents, I got the grey and the black. Was on holiday and had limited access to computer and internet resources!
GTAman
Jul 3, 2024 07:29 PM
TheExaminer
Sep 6, 2015 11:40 PM
Ian Irvine
Sep 4, 2015 08:08 AM
andy74
Sep 3, 2015 08:41 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
