700r4 issue
Old May 30, 2010 | 06:00 PM
ChevyMan1990's Avatar
Car: 1986 Camaro Iroc-Z
Engine: Factory 305 sbc
Axle/Gears: 3.42 limited slip
700r4 issue
I recently traded for an 86 irocz. Fromer owner told me that he burnt 3rd and OD out of tranny but brought another to replace it. Well after the swap the tranny wouldnt shift out of park. The shifter itself will go into any gear but the tranny acts like its not shifting at all. I've heard that getting the cables right on a factory TPI car was hard and I've put a gallon and 3 quarts of ATF and still no shifting. I'm new to transmissions so I have no idea what it could be. Everythings is hooked up like it was. Is my 700r4 trash or did I miss something? thanx
Old Jun 1, 2010 | 02:09 PM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
Re: 700r4 issue
Even with a misadjusted TV cable, you should be able to shift into any gear. I would suggest getting a trans pressure gauge and seeing what the trans is doing. You may have to pull it anyway but this will tell you for sure. Do an internet search for what pressures coincide with each gear.
Old Jun 1, 2010 | 02:49 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: 700r4 issue
You could verify with the car off and the emergency brake on that the shifter does move and the lever on the transmission (driverside) moves along with shifter. If the cable is loose or not connectted that's probably the issue. Just make sure when checking you have the wheels blocked so they don't roll and the brake is on. You don't want the car moving when you put it in neutral and are looking underneath it. If the shifter moves but the cable doesn't that means it either came loose (e-clip on the shifter) or it has a broken cable.
Old Jun 1, 2010 | 03:49 PM
Re: 700r4 issue
Alright I'll give it a try. I was told that the front pump may be bad, any thoughst on that?
Old Jun 1, 2010 | 03:51 PM
Re: 700r4 issue
As for the cable it all appears to be hooked up right. It moves when the shifter shifts.
Old Jun 1, 2010 | 04:36 PM
Engine: 383 SBC
Re: 700r4 issue
If the pump is bad that would explain the low pressures and it not shifting. You could call Pro-Built Automatics. Dana is very knowledgeable and friendly with questions over the phone. He also sells replacement parts/rebuild kits/full transmissions. He's always been very friendly to me when I've had questions, because he knows he might have a potential customer. Dana - 909-795-1876 http://www.700r4l60e.com/
Old Jun 2, 2010 | 01:46 AM
Re: 700r4 issue
Alright I'll give him a call. Thanks.
jklein337
Sep 19, 2018 06:23 PM
TheTraut88
Sep 7, 2015 05:22 PM
Americanmouse
Sep 7, 2015 12:10 PM
greenyone
Sep 2, 2015 03:39 PM
someone972
Aug 30, 2015 12:52 AM
