transmission problem?
Old Jun 3, 2010 | 12:02 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
just few days ago i was trying to haul *** and shift into second and i struggled putting it in.
it does not whine, doesn't not grind or pop out of gear. same thing for 3rd gear. but it just doesn't go in smooth like before. yet alone the pro 5.0 shifter is kinda choppy but its just not smooth to put in.. it drives normal shifting under 3k.
im not pushing 400rwhp. its a daily driver ls1 third gen
any suggestions?
low on tranny oil ?
i re bleed my hydraulics and greased up by the pivot on the shifter. it looked dry felt a bit better but still .
i believe i have a tiny leak from my rear main seal can this be the key to this problem? moisture on the clutch ?
im going to drain out the tranny fluid tmrw. if not its time to drop the tranny.
Old Jun 4, 2010 | 03:52 AM
duckmanquacker's Avatar
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
Re: transmission problem?
Are you using the factory LS1 hydraulics? I recall they had an issue with doing quick shifts, as they didn't like it at times, usually a soft peddle follows.
Old Jun 4, 2010 | 07:16 AM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
It's call the "drill mod" to open up the restriction in the stock hyd line. I've already suggested in over on LS1tech and was blown off..
Old Jun 4, 2010 | 03:55 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
sorry man. didnt mean to blow u off. but i havent done that yet. do you suggest to do that first? i might post some pics of the small leak.
ita kinda understandable that oil on the pressure plate will affect the clutch performance noh?
i just hope its not the tranny. i just hope its a leak .
i also believe if it was the tranny i would notice the issue little by little. this just happened out of nowhere.
Old Jun 4, 2010 | 03:57 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
yea im ussing the 4th gen pedals and hydraulics
Old Jun 4, 2010 | 05:02 PM
I'd follow his drill mod, it should help clear things up
jhawkeye
May 25, 2022 06:33 PM
AussiePr0nCar
Mar 6, 2020 04:04 PM
Cleotiz
Jan 6, 2018 08:56 PM
BlackphantomZ28
Apr 24, 2016 08:14 AM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
