T-5 Swap help. I don't think clutch is disenaging?
Old May 26, 2010 | 05:04 PM
JTNKTZ's Avatar
Car: 1991 Camaro RS/1989 Vert RS
Engine: 355/350
Transmission: T-5/T-5
Axle/Gears: BW9bolt3.45posi/3.23 Posi
Well in nuetral when I start the car I try to put it into first. Won't let me.
When I start the car in first it moves forward with the clutch pushed in all the way.
Friend said that I need to bleed the clutch... I'll try that later.
I read from some else it sounds like the input shaft is stuck to the pilot bearing? I put grease in the pilot bearing and around the input shaft... how could it do that?
Old May 26, 2010 | 05:46 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: T-5 Swap help. I don't think clutch is disenaging?
bleed the clutch first
did yo uinstall the TO bushing the right way, top is wrong, bottom is right
Old May 26, 2010 | 05:48 PM
JTNKTZ's Avatar
Engine: 355/350
Funny you posted that. I made that mistake once. I fixed it so it wasn't underneath the clips.
But I will bleed it tomorrow cause I have to do school work.
I'm just getting ideas as to how badly I'm screwed...
Also as a response to your signature, it is the guy who inherits all those tools that wins :P
Old May 28, 2010 | 06:52 AM
ShMaCk2004's Avatar
Car: 1987 Camaro IROC-Z
Transmission: LS1 T56
Axle/Gears: Richmond 3.73
any luck bleeding the clutch?
the input shaft can get stuck on the pilot bushing no matter how much you grease it. It happened to me 2 out of 3 times. I just put it in first, let of the clutch completely, held down the brakes, then started cranking the engine. After a few cranks it broke free and and started up and worked fine.
Old May 28, 2010 | 06:49 PM
JTNKTZ's Avatar
Engine: 355/350
Yeah it worked. But now I have a massive click comeing from the bell housing. I am thinking its those grade 8 bolts I used for the pressure plate. Someone told me they will work but I found out they wouldn't AFTER everything was installed...
Will these work for my motor?
http://www.summitracing.com/parts/ARP-130-2201/
Old May 28, 2010 | 06:57 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
teh grade 8's are probably fine for the pressure plate, but the flywheel to crank bolts need to be specific, regular ones heads are generally too tall
Old May 28, 2010 | 07:52 PM
JTNKTZ's Avatar
Engine: 355/350
Well I got specific flywheel bolts... Any other ideas as to what the clicking could be than? It's inconsistent click. Wasn't thre when I first started up the car and I am 90% sure it's coming from the transmission because I can feel it in the shifter and I can hear it coming from the back back of the motor.
I just jacked up the car and felt around. I didn't feel anything on the bell or the transmission. So it's gotta be the actual driveline and those bolts are the only things I can think of.... Felt the starter too and it's fine.
Old Jun 1, 2010 | 04:38 AM
ShMaCk2004's Avatar
does it still make the noise the the clutch pressed down and the trans in gear?
Old Jun 2, 2010 | 10:50 PM
JTNKTZ's Avatar
Engine: 355/350
Always makes the noise.
Old Jun 2, 2010 | 11:02 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Are ya sure the TO bearing is on right?
It will sound like its clicking as it rubbin on the clutch disc center tangs and then when it stops clicking, they done wore through and its time for a new one.
Been there
One I got in the clutch kit was crap compared to what came off, got a nice beefy federal mogul one off the shelf instead on the 2nd times.
Old Jun 4, 2010 | 10:04 PM
JTNKTZ's Avatar
Engine: 355/350
Been there
Well it was the TO. The top plate bent outwards for some reason so I am going to have to bend it back. The TO bearing inside diameter is shaped like a tear drop, where should the end of the tear drop be pointing when I put it on the clutch fork? Drivers side, passenger side round or sky?
Old Jun 4, 2010 | 10:11 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
You got one of them cheap TO bearings then, real thin n flimsy, get a good name brand new one of the shelf. No way it will bend.
jharrison5
Aug 19, 2015 05:53 PM
sonu1975
Aug 11, 2015 08:38 AM
rsrmoore
Aug 7, 2015 08:44 PM
tero
Aug 6, 2015 06:34 PM
