Clunking sound? Help!
Old Jun 3, 2010 | 11:07 PM
j3rry92's Avatar
Car: 1988 Pontiac Firebird
Engine: 2.8L V-6
Axle/Gears: stock
Alright so my car is a 88 firebird with a 700r4 transmission. I just recently had it rebuilt about 6 months ago. The car has drove fine since then until recently. I don't know of it is a transmission problem or something In the differential, but if I take off slow from a stop my car will drive fine. If I try to accelerate even a little hard the makes a loud clunking noise. It sounds like it is coming from the transmission hump or driveshaft, but you can also feel the wheel not want to grab traction properly. I was told that it could possibly be transmission mount? If you all have any idea or information that could help it would be greatly appreciated. Thanks, Jerry
Old Jun 3, 2010 | 11:35 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: Clunking sound? Help!
Check the basics--
shifter, trans mount, torquearm mounts, U-joints, panhard bar, swaybar, lower control arms, unusual rear axle slop.
Old Jun 3, 2010 | 11:45 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
classic trans mount, I'll bet the rubber one is shredded. Buy a poly trans mount from prothane or energy suspension, and you'll never replace it again
Old Jun 4, 2010 | 12:26 AM
j3rry92's Avatar
Engine: 2.8L V-6
Axle/Gears: stock
Thanks for the input. I figured that was most likely the case. I've heard similiar stories but just wasn't sure. Thanks again for your alls time
Old Jun 4, 2010 | 02:44 AM
383Bandit's Avatar
Transmission mount! If its noisy all the time that would be my bet. Everyone else pretty much posted what all it could be.
Lbibb
May 5, 2016 12:00 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
wanext
Oct 6, 2015 12:18 AM
Fanatic1074
Oct 2, 2015 03:47 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
