t56/454 flywheel?
Old Jun 4, 2010 | 04:35 PM
87bluebird's Avatar
Car: 1987 pontiac firebird
Engine: 6.5 turbo diesel
Transmission: t56
Axle/Gears: Ws6 axle
t56/454 flywheel?
i got an 87 firebird that currently has the 2.8 v6 and 700r4 auto trans. I got a 98 vortech 454 with the ecm and wiring harness for 1200 bucks. From a wrecked 98 Silverado 2500hd. i don't want an automatic transmission so i got a t56 manual trans, clutch and pedal assembly from 4th gen 95 camaro lt1 car for 700. i plan to drive the car like it is this summer and when i take it off the road for the winter i will start the build. rite now i am just gathering parts and info.thanx
1)alright i got a couple of questions first what kind of flywheel do i need to get?
2)is this transmission a different length then the stock transmission? if so do i need a different drive shaft and torque arm. would the ones from the 95 camaro work?
3)are there any other things i need to get to use this transmission?
Old Jun 4, 2010 | 09:44 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: t56/454 flywheel?
If you don't find the aftermarket 2pc seal LT1 flywheel balanced for a 454, you can get the one for an 85-down 350 and use a balance plate in between the flywheel and the crank. (they make those balance plates for 400s and 454s.)
A starter for the 153 tooth flywheel needs the in-line bolt holes in the block; should be there on a 98 block.
Old Jun 4, 2010 | 09:45 PM
jmd's Avatar
jmd
2) No
3) Start searching and reading more.
Old Jun 4, 2010 | 09:58 PM
87bluebird's Avatar
Transmission: t56
1)do you know how a balance plate would cost and where to get one?
2)so i should get a starter for a 98 silverado rite?
thanx and i have been reading different threads like online170 and MrDude_1's threads
Old Jun 4, 2010 | 11:20 PM
jmd's Avatar
jmd
98 454 starter will be for a 168 tooth flywheel. Use one for a 95 LT1 - 153 teeth. Make sure your block has the right bolt holes for it.
http://www.google.com/products?hl=en...%20plate%20454
Looks like they're up to $60 at a few places.
Old Jun 5, 2010 | 12:17 AM
87bluebird's Avatar
Transmission: t56
so i get the flex plate the starter and fly wheel from the 95 camaro will work?
Old Jun 5, 2010 | 12:29 AM
87bluebird's Avatar
Transmission: t56
will this work with a 98 454?
o
n an ebay add for one of these it says "This a 454 BBC flywheel balance plate used to enable use of a 350 standard flywheel with a BBC 454 externally balanced crankshaft. No need of purchasing an expensive 454 flywheel. Fits all two piece rear main seal crankshafts 1970 to 1990." is the 98 a two piece rear main seal or did they stop that in 1990? and what difference will the rear main seal make?
Old Jun 5, 2010 | 01:24 AM
duckmanquacker's Avatar
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
91 and up BBC are a 1 piece rear main seal.
Old Jun 5, 2010 | 12:33 PM
87bluebird's Avatar
Transmission: t56
would a balance plate work with a 1 peice rear main seal?
Old Jun 5, 2010 | 10:40 PM
I'm not familiar with any balance plates being drilled for the 1 piece crank pattern, tho there may be some, I have a mark 4 block with 2 piece main which uses the same patern as the 2 piece SBC.
Old Jun 15, 2010 | 08:59 AM
jmd's Avatar
jmd
Unlike the small block, the flywheel to crank bolt pattern didn't change when the Mk V got 1pc rear seal.
The Mk VII got metric bolts. Yours is a Mk VI.
Old Jun 15, 2010 | 01:06 PM
87bluebird's Avatar
Transmission: t56
so your your saying that the balance plate wont bolt to it cuz it has a different bolt pattern. is there one made for the 98's bolt pattern?
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
el_muerte
Sep 16, 2015 12:01 AM
