Posi rear?
Old Jun 8, 2010 | 07:55 AM
vinny83's Avatar
Car: '83 Camaro Berlinetta
Engine: 305 with aluminum heads, voodoo cam
Transmission: 700r4 auto
Axle/Gears: 10 bolt w/ 3.73 gears
Posi rear?
hey, i have a 1983 camaro berlinetta ( i think ) that has a posi rear end..idk the gears in it, but it does have drums brakes, how hard or expensive is it to switch over to discs in the back? the drums caused me to crash the car in the rain. front wheels took all the weight and slid me under a truck.
Old Jun 8, 2010 | 08:07 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Posi rear?
Welcome to TGO.
Berly info: https://www.thirdgen.org/1983-chevy-camaro
10-bolt info (since the original rear may have been swapped out at some point. The link also provides info on drum to disc converstion): https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Jun 8, 2010 | 08:49 AM
Convoy25's Avatar
Car: 95 Z85 S10, 99 Formula
Engine: 4.3 CPI , LS1
Transmission: NV3500, T56
Axle/Gears: 3.08, 3.42
Re: Posi rear?
to see if it has a posi or not put your foot on the brake and press the gas until the tire(s) spin. if one spins you have a peg leg, if both spin you have a posi.
to switch over you can either swap out the whole rear end or buy one of the conversion kits.
though correct me if i'm wrong the front does about 70% of the braking. you could upgrade the fronts to the 1le braking.
hectre13
Dec 11, 2023 08:14 AM
Reddeath210
Oct 6, 2015 08:20 AM
tcflint
Exterior Parts for Sale
Aug 26, 2015 05:45 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
AkDrifted
Aug 17, 2015 07:45 PM
