Scatter shield, changing trans patterns
Old Jun 8, 2010 | 12:25 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Hey guys.
Any of you ever consider re-drilling a steel bell housing to mount a T56, or ford transmission?
It seems to me like a logical approach to keeping your feet in a clutch explosion, and being able to run alternate manual transmissions?
-- Joe
Old Jun 8, 2010 | 04:49 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Scatter shield, changing trans patterns
so long as there is no issue with input shaft length an whatnot, and you are welding nuts or something else as reinforcement to the backside of the bell, i see no issues.
Old Jun 8, 2010 | 05:01 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
The only thing brightly off the top of my mind, is something like a T56 doesn't really have a bearing retainer so I'm not sure how to keep the crank line centered.
I guess a tremec or ford wouldn't be a problem.
I wonder what the input shaft length is of a LS1 version of a T56, vs like a saginaw or muncie, t5, etc.
-- Joe
Old Jun 8, 2010 | 05:34 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
The T56 is piloted by dowels instead of a bearing retainer.
Aftermarket T56 that uses an adapter plate to bolt to a Muncie/T5 bell is longest, then LS1, then LT1. Dodge is somewhere in between A/M and LS1 IIRC.
Thinking of going T56?
Old Jun 8, 2010 | 05:50 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Not sure what I'm gonna swap it to. I'm thinking of going scatter shield because i've just seen too many references to clutch explosions and I like my feet. I've already had an eye injury in the shop, don't need to be an amputee as well.
I'd like an overdrive. I have an 833 with the mopar pattern with a dual pattern sbc bell, but aluminum. Thinking of selling it and running a scatter shield and my saginaw, until I find a good OD trans.
I need to find some sort of reference chart showing what the input shaft lengths are on various transmissions. I could even run a ford trans if I wanted to, just would need to turn the collar on the trans down to 4.75/4.86".
-- Joe
1992 Trans Am
May 10, 2023 07:19 PM
maroe624
Apr 16, 2017 08:29 AM
mustangman65_79
Sep 1, 2015 03:51 PM
kyle5647
Aug 15, 2015 11:56 PM
gta power
Aug 13, 2015 06:15 AM
