Axel Cover With Fill Plug
Old Jun 12, 2010 | 08:57 PM
Bigwavedave's Avatar
Car: 91 Z28 1LE
Engine: 5.7
I have stock differential and replaced the cover with the Jegs, which includes a fill and drain plug. While filling it took much more than usual oil to fill. It's been a while, but it seemed like I added much more than normal. I then checked the stock fill plug, and oil came out.
Is it okay/better to fill to the higher level from the new cover, or should I only fill to the stock fill level? Will I hurt anything with more oil in it?
I used about four bottles. I thought it only took two the last time.
Old Jun 12, 2010 | 09:14 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: Axel Cover With Fill Plug
I would probably take out the stock fill plug but fill it through the cover just because its easier. 4 quarts is a lot.
Old Jun 13, 2010 | 02:41 PM
big gear head's Avatar
Remove the stock fill plug and let the excess oil run out. Do not use the hole in the cover as a fill level. These covers have the hole too high and excess oil can cause foaming, which can lead to gear failure.
Old Jun 13, 2010 | 03:20 PM
Stephen's Avatar
Car: 87 GTA
What brand cover did you buy? Is your axle a 9 or 10 bolt?
Sounds like the cover needs a redesign, if the plug that that high.
Old Jun 13, 2010 | 04:04 PM
Car: 91 Z28 1LE
Engine: 5.7
Thanks for the info.
I essentially drained the excess through the stock fill hole.
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
db057
Sep 4, 2015 07:57 AM
g.l.mos
Aug 22, 2015 12:02 AM
