clutch pivot ball 'shape'
Old Jun 14, 2010 | 01:35 PM
87SSTPI's Avatar
Car: 1987 Monte Carlo SS
Engine: Vortec headed 350
Transmission: '89 WC T5
I am trying to figure out exactly what my pivot ball 'should' look like. At first, I figured the one I have HAS to be worn, but if you were to look at it very closely, it doesn't seem possible that it could have worn in like this without also leaving a smooth/shiny surface.
This is from an ~89ish~ camaro with a WC T5 trans and hydro clutch setup.
Maybe someone could offer their input as to wether or not this ball is even close to the shape it should be. I was planning on just filling it in (weld) and slowly/carefully reshaping the ball.
I know they are a fairly cheap item (if you can find one anywhere) but due to recent shoulder surgery and the fact that I'm not currently able to return to work for another month, I can't justify spending any money on "car stuff".
Here is my ball in it's present form. If anyone has a picture of an actual 3rd gen f body clutch pivot ball then I would simply compare it to that and make up my mind on what I want to do. Even within GM specific cars, the length/etc does in fact vary depending on application. I just want to stick with a stock one so an adjustable one isn't something I want to mess with.
Old Jun 15, 2010 | 03:24 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: clutch pivot ball 'shape'
That looks totally normal other than the moon shaped groove cut in it. IMO, I'd spend the few bucks and get a new one. The 84-92 pivot ball is threaded differently than the 83-down mechanical ones.
Old Jun 15, 2010 | 10:12 AM
87SSTPI's Avatar
Thanks jmd for the reply.
Much appreciated
Old Sep 9, 2010 | 11:06 AM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
Where can you get one aside from OEM? I can't find the right one anywhere other than Vintage Auto
devilschariot
Feb 25, 2016 03:08 AM
Drone358
Dec 10, 2015 08:16 PM
jtwoods4
Sep 3, 2015 05:39 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
