tune EPROM for Manual tran?
I'm looking at buying a 350TPI f-body (which we all know is the auto tranny) because there are some clean un-molested examples in my area for under 5 grand. Only thing is I'm one of those people that loves a perfectly timed heel-toe down shift. So I would be entertaining a T-5 swap, only prob is I read somewhere that the stock tune in the EPROM is set up for running an auto trans(duh) and that it won't run quite right if I swap in manual. Any thoughts?
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: tune EPROM for Manual tran?
Start with a Vette bin. They made manual L98's in those cars.
The vette bin sounds good. looks like the only difference is the aluminum heads so I probably just retard the the timing 5 or 10 degrees to prevent pinging with the cast iron heads. I was thinking I could probably drive it un-tuned its just that it'll idle higher than it needs to.
Car: 89 Iroc-z
Transmission: TH400
You can run whatever manual trans L98 bin is available and copy in a Iron head L98 timing table and other settings if you want. It should work out well.
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
I'm in that boat; but need something for a 305/T5 combo. Where do I start??
Car: 89 Iroc-z
Transmission: TH400
Need to find out what bin codes came from stock T5 305 cars. Then you can try to download a bin file off of moates.net or other DIY tuning sites.
Might beable to locate a stock prom for a 305 T5 combo in the classifieds and just read the stock bin.
1992 Trans Am
May 10, 2023 07:19 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
