TV cable replacement without dropping transmission
Old Jun 19, 2010 | 07:16 PM
Aldakoopa's Avatar
Car: 1987 Trans Am
Engine: 305 4 bbl
Transmission: The kind that goes "kachunk" in 1st
Is it possible to replace the TV cable without dropping the transmission? I have a 1987 Trans Am and a parts car exactly like it. I was replacing the flex plate and was just about to bolt the transmission back up but I broke the TV cable in the process, and I don't really want to drop the transmission in the other car so I was wondering if it was possible to just get it off without doing that so I can put it on my other car.
It looks really tight under there, but I haven't jacked it up yet. It's sitting in a grassy field and I'm taking a break from transmissions for the moment. Just curious if anyone has done it and if it will be relatively easy compared to everything else I've done today.
Old Jun 19, 2010 | 07:39 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: TV cable replacement without dropping transmission
I did mine without dropping the tranny. It is tight... I have small hands, so I got it with a small ratchet.
Old Jun 19, 2010 | 07:45 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
It's possible - I've done it. The PITA part is trying to get your head up in there far enough to see the little hook inside the tranny that hooks into the hole on the cable. It definitely helps to have an extra pair of hands - someone to pull on the other end of the cable and keep it taut so it doesn't come unhooked until you get the hold-down screw in place and get the cable secured.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
mizz0313
Aug 12, 2015 06:45 AM
