86 Firebird 10 bolt LSD or Posi?
Old Jun 25, 2010 | 12:44 PM
Driver59's Avatar
Car: 1986 Pontiac Firebird
Engine: Custom built 350
I was wondering if my stock 10 bolt rear is a LSD or a actual posi. Right now I have the wonderful "one-wheel peel" that I'm trying to cure.
I was wondering if I can rebuild the diff, with new clutches or if I need to swap to a true posi diff.
Thanks for the info guys
Old Jun 25, 2010 | 12:55 PM
89_RS's Avatar
Car: 2003 F-150
Engine: 4.6L Modular V8
Transmission: 4R70W
Axle/Gears: Ford 8.8"/3.55 LSD
Re: 86 Firebird 10 bolt LSD or Posi?
A stock 10-bolt is an open differential that has 2.73:1 gears. That one-tire-fire you're getting is because the differential is open, meaning that the wheel that slips gets all the power. You would have to buy an LSD differential carrier, possibly new gears, and even new axles depending on the splines the carrier is designed for to cure that one-tire-fire.
It won't be as simple as opening the diff and replacing a few parts. This would almost be a major rear end rebuild. This is a list of a few of the LSD style carriers avaliable for a 10-bolt. Also in that list are a few lockers. They perform like a locked diff under acceleration, but open up during turning to allow for differentiation.
http://www.summitracing.com/search/Department/Drivetrain/Section/Differential-Rear-End-Components/Part-Type/Differential-Carriers/Axle-Model/GM-7-625-in/Stock-Case-Style/Open-case/Make/CHEVROLET/?Ns=Rank|Asc
Also, this tech article has some great info about how to rebuild your 10-bolt: https://www.thirdgen.org/beefinguprear
If you decide not to rebuild the 10-bolt and just swap out the rear end completely, the cheapest route is to get a Strange Dana S60 rear from Spohn. You would need a new driveshaft and brakes for it fit your car and possibly even a torque arm.
http://www.spohn.net/shop/1982-1992-...-Complete.html
Old Jun 25, 2010 | 02:12 PM
big gear head's Avatar
LSD and Posi are the same thing. Posi is Eaton's brand name for their LSD that was used in the Chevy cars of the '60s and early '70s. The rear end in your car could have a standard differential or a LSD, depending on how it was ordered. To install a LSD read this. http://www.nastyz28.com/forum/showthread.php?t=19773
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
Dialed_In
Aug 20, 2015 01:45 PM
knight72
Aug 10, 2015 09:32 PM
