broken mounting tab
Old Jul 6, 2010 | 08:16 PM
jerodo8008's Avatar
Car: 1985 Trans Am 1988 Chevy c1500
Engine: 5.7 v8 /4.3 v6
Axle/Gears: 3.08 & ?
broken mounting tab
ok, attached is a picture of a broken mounting tab on the 700r4 tranny out of my 85 ta that came stock with a 305 carb. I plan on having the engine rebuilt in the future, can something like this just be put off til then? or does one mounting hole really make that much of a difference? I'm just gonna drop a cheap 305 in to get it running again.
it's on the passenger side, third from the bottom.
Old Jul 14, 2010 | 04:34 PM
vasquezmrysvll's Avatar
Car: 1985 California Iroc
Engine: HSR ZZ4 0411 swapped
Axle/Gears: 3.23 posi
Re: broken mounting tab
im curious as to if any ill effects can be expected.....mine was dropped during rebuild and busted the same tab off. ....subscribed!
Old Jul 14, 2010 | 04:42 PM
duckmanquacker's Avatar
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
As long as your not getting on the car hard you should have no effect, However, when you do accelerate hard it will slightly twist the bellhousing possibly binding the input shaft. another option to help that live a little longer is to clean all grease out of the break, drill a couple of holes in the broken area, mix up some JB weld and clamp together till dry. This is an OK fix for a DD but not for a performance build.
Old Jul 14, 2010 | 07:57 PM
jerodo8008's Avatar
awesome, thanks. like I said I on;ly plan on putting a stock~ish 305 in just so that I can drive it. this winter i'm gonna build up a supercharged 383 and get a new transmission.
skeltor
Feb 2, 2016 10:37 AM
Eric-86sc
Exterior Parts for Sale
Nov 16, 2015 10:20 AM
snakeshooter
Sep 7, 2015 11:15 AM
FormulasOnly
Sep 6, 2015 10:42 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
