another 6 speed swap question
Car: 1983 Z28
Engine: 355
i am pretty sure i saw a direct bolt in six speed that uses all of the original equipment of the 5 speed. cable clutch and everything. i searched everywhere and cant find it and i'm starting to think i am going crazy. anyone else heard of this or is it just me making things up?
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Re: another 6 speed swap question
http://www.sallee-chevrolet.com/BorgWarner/bwt56.cfm
It's called an Aftermarket or Retro-fit T56.. Has the weaker M29 gearset. Spohn sells Xmem's for them. They do have a directed fit shifter location and mechanical speedo, but almost impossible to find used. New, they'll set you back $2500.
You can make a similar setup by putting an adapter plate on a Fbody LS1 T56. You'll get the stronger MM6 gearset, but will have to cut the tunnel for the shifter and will have an electronic VSS.
http://www.thegearbox.org/catalog/it...17/4803441.htm
Car: `86 SS / `87 SS
F-bodies never used a cable clutch.
The "aftermarket" T56 has a longer input shaft.
With an adapter plate it bolts to the 82, 83, or 84-92 Muncie pattern bellhousings.
The shifter is close but not exactly where the T5 one goes.
But, with the bellhousing + adapter plate + trans., it is longer than an OEM setup and requires a shorter than stock 84-92 driveshaft.
Except for the lack of a mechanical speedo drive, I would rather have a 93-97 LT1 T56 over the aftermarket T56.
Keep searching; there's gotta be threads on here about it.
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
There is solution to the lack of a mechanical speedo drive, and it is also mechanical.
1992 Trans Am
Aug 8, 2015 08:16 PM
