700r4 no second gear od slips
Old Jul 8, 2010 | 11:34 PM
rayray1991's Avatar
Car: 1991 corvette
Engine: 5.7L 350
Transmission: th 700r4
I have a 91 corvette with a 350 tpi wit a 700r4. first gears fine but when it goes from 1 to 2 its like it goes into neutral then after about 3 seconds it goes into 3rd.also while driving today if u hold the car at 55mph the shift light comes on. never work ontrannys befo but what ive heard its the 2/4 band.any ideas on what the exact problem is or idea on what to check? thanks for your help.
Old Jul 9, 2010 | 02:17 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: 700r4 no second gear od slips
Is it the original transmission? If so, it finally failed and you need it rebuilt. If its been rebuilt before, it failed again and you need it rebuilt.
Old Jul 13, 2010 | 12:17 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
You're losing the band that holds 2nd and OD. I've had this happen. I kept driving it for another year. Progressively more throttle through first gear, up past 4500 rpm, then lift, it goes to third, then ease back into the gas so it won't try to kick down into second.
Old Jul 13, 2010 | 06:12 PM
rayray1991's Avatar
Car: 1991 corvette
Engine: 5.7L 350
im going to have it rebuild next week and need to know if putting a shift kit in it and or a lock up converter would be a good idea. it's gonna be a daily driver/toy.
Old Jul 14, 2010 | 03:35 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
keep the lockup feature. It helps mileage, noise and engine life, but doesn't affect performance enough to measure. Do the shift kit, most such kits have at least 2 stages. Stage 1 is usually called RV, stage 2 is usually race or semi-race. Stage 1 generally is best for long transmission life, and generally won't bark the tires when making the full-throttle upshift into second. It feels like a performance trans you can live with all day every day. Stage 2 is for guys in their 20s.
Old Jul 14, 2010 | 04:57 PM
rayray1991's Avatar
Car: 1991 corvette
Engine: 5.7L 350
i was looking into a stage 2 shift kit and i know there good for the tranny but could this aso put mre stress on other parts and cost me more money in the long run
Hotrodboba400
Dec 10, 2019 07:07 PM
billybob6110
Sep 23, 2015 01:30 PM
TheTraut88
Sep 7, 2015 05:22 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
