9 bolt lubricant
Old Jul 11, 2010 | 04:32 PM
m smith's Avatar
9 bolt lubricant
Does anyone know what is the proper gear lube for Borg Warner 9 bolt rear ends.Can you use 80-90w oil.I know it is a cone type LSD so I would assume you do not need an additive to quiet the clutches like you would in the 10 bolt GM.Thanks.
Old Jul 12, 2010 | 08:58 AM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
Re: 9 bolt lubricant
I've used Mobil 1 synthetic 75/90w gear oil with the GM LSD additive with no problems.
Old Jul 12, 2010 | 09:27 AM
skinny z's Avatar
Although conventional thinking says no additive is required in the 9 bolt posi, I've found that a friction modifier (I use a Ford product on advice from a fellow racer) quiets the rear considerably when maneuvering through parking lots and such. Admittedly, mine is a high mileage unit with lots of abuse (including a broken pinion).
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Numbah-1
Sep 12, 2015 08:57 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
