rear end swap
Car: 86 Camaro
Transmission: th350 w/2500 stall
rear end swap
I'm getting ready to swap out my stock 10 bolt open rear end w/drums from my 86 Camaro. I am replacing it with a 10 bolt posi w/3.73 gears and disc brakes. I am told that there is a piece in the master cylinder that needs to be removed. Anyone know? And how about my stock e-brake cables. Will they work, or should I get the cables to?
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: rear end swap
get the cables too.
you need to swap the proportioning valve, its the block under the brake master cylinder that all the brake lines run in and out off. they are different for drum/disc and disc/disc cars, they are a couple different disc/disc ones for that matter as well.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: rear end swap
Many of your questions will be answered in the link to follow:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
JamesC
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
all for the help. That link just about covers it all. I really appreciate it.
