Need posi 83 Trans Am
I took the teeth off the gears with a new engine I wanna beef up my original diff with new guts as cheap as I can and have posi. Naturally I am in Canada...so what do I buy? how much ? can it be bought all parts for 1000$?
Re: Need posi 83 Trans Am
I recommend a new 28 spline Eaton Posi and a set of 28 spline axles. You can get the axles from a '90 to '92 Camaro or Firebird, or get a new set. A good installation kit with Timken bearings and the super shim set is also recommended. Use quality gears, not a bragan brand. All of this will probably be around $1000 to $1200, but might be different in Canada.
Car: `86 SS / `87 SS
agreed w/ big gear head.
You might add a bearing cap support rear diff. cover (has two set screws in the cover) - some people say they can't help, but others like them.
1992 Trans Am
May 10, 2023 07:19 PM
ambainb
Apr 25, 2016 09:21 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
