t56 engine combatbility
Old Jul 15, 2010 | 02:11 PM
the rookie24's Avatar
Car: 1992 rs stock for now
Transmission: auto
im lookin to swap out my 305 and 700 and wanted to do a t56 and ls1 but im not really wanna wire it so i decide i wanna do a carbed 350 less wires =)
but i don't no what year engines will work with the t56 i have 1992 camaro rs and i can get a 350 crate engine out of my dads friends truck for 300 bucks he put a new engine in a roting truck lucky me
Old Jul 15, 2010 | 03:01 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: t56 engine combatbility
The T56 will bolt to any small or big block chevy. What flywheel you use will be dependent on what year motor it is.
Old Jul 16, 2010 | 07:25 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
You can also carb the LS1 - there's some great threads on it at LS1tech.com
Old Jul 16, 2010 | 09:43 PM
Transmission: auto
i know i can carb the ls1 but it a lot of money to do the complete swap and i can get a good 350 for 300 buck the tranny is gunna cost now with the t56 i know there two version one for the lt1 and the ls1 which one do i need to get to use it with a old 350 smallblock
Old Jul 16, 2010 | 09:50 PM
built91Z28's Avatar
The LT1 setup is the easiest and cheapest. The T56 sticky above has almost every answer to any question you may have.
BlackphantomZ28
Aug 31, 2015 10:29 AM
jharrison5
Aug 19, 2015 05:53 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
