4L60E
Old Jul 20, 2010 | 01:12 PM
ChevyMan1990's Avatar
Car: 1986 Camaro Iroc-Z
Engine: Factory 305 sbc
Axle/Gears: 3.42 limited slip
4L60E
Is it possible to use a 4L60E in a 3rd gen? If so does it require any special work?
Old Jul 20, 2010 | 01:23 PM
giszo's Avatar
Car: 1992 Camaro RS
Engine: 3.1L V6
Transmission: 700-R4
Re: 4L60E
You will definitely need a Transmission Control Unit (TCU) to use a 4L60e.
Old Jul 20, 2010 | 01:27 PM
Re: 4L60E
Appreciate it, anything else?
Old Jul 20, 2010 | 01:29 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: 4L60E
Maybe swap out the tail shaft housing so your torque arm will bolt up. You will not only need the TCU but the associated harness.
Old Jul 20, 2010 | 01:30 PM
Re: 4L60E
Yea I figured I'd have to do that.
Old Jul 30, 2010 | 03:52 AM
venomouse's Avatar
Re: 4L60E
It will work in 3rd gen V6/V8 with an electric VSS and 700R4/4L60 tail shaft housing.
Old Jul 30, 2010 | 04:45 AM
89fbirdformula's Avatar
On Probation
Car: 1989 Formula,1991 z28
Engine: 400 Vortec Hsr,496bbc
Transmission: TKO600,TH400
Axle/Gears: 9"4.10, 9"3.73
Re: 4L60E
unless the trans is built substantially, and you got it VERY cheap... you're better off finding a 700r4...
TCU's are expensive, 800 something from TCI last i knew, plus the harness which was another 150 or something like that.
Old Oct 22, 2010 | 01:02 PM
Camarillo's Avatar
Car: 1990 RS Camaro
Engine: 1990 305 tbi lo3
Re: 4L60E
According to my GM shop manual, my 1990 Camaro rs tbi 305 is equipped with the 4l60, (formerly THM 700-r4) is there any difference between a 700-r4 and a 4l60? what is the difference between a 4l60 and the 4l60e?
Old Oct 22, 2010 | 01:05 PM
giszo's Avatar
Car: 1992 Camaro RS
Engine: 3.1L V6
Re: 4L60E
4l60 is the same as the 700r4, it was just renamed in the latest years of production.
4l60e is an electronically controlled version of the 4l60, so 4l60e requires a separate TCU (Transmission Control Unit) to be able to work properly.
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
Nervous2
Oct 8, 2015 10:53 PM
LSXcamaro
LSX and LTX Parts
Sep 17, 2015 11:17 PM
IROCZ1989
Sep 4, 2015 11:54 AM
f-bodyz28
Sep 2, 2015 05:03 PM
