shift kit ?
Old Jul 27, 2010 | 09:56 PM
89chevycamaroRS's Avatar
Car: 89 Camaro RS / 02 Silverado Z71
Engine: 1999 LS1
Transmission: 4L60e
Axle/Gears: 3.73 detroit truetrac
shift kit ?
i am in the process of putting a bigger engine in my car. i currently have a 700R4 for a tranny now. i want to get it re built since as far as i know it has never been rebuilt and it has 146,xxx miles on it.
i want to get a shift kit for it also. i already have a B&M ratchet shifter in it. but when i would shift manualy up it hesitats between gears ( like it should to make shifts smooter) but i want to be able to hit my shifter and get to that next gear like now. will a shift kit do that for me. i also want to be able to put it it drive and just go without shifting so i dont want a manual valve body.
what do you recomend
Old Jul 28, 2010 | 05:01 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Re: shift kit ?
I would contact Dana over at Pro-built Automatics. He knows the 700r4 and frequents the boards here a lot. Just get the whole rebuild kit from him, he includes a modified Transgo shift kit in most of his rebuild kits, if not all of them.
Old Oct 24, 2010 | 08:17 PM
Engine: 1999 LS1
Transmission: 4L60e
Re: shift kit ?
i have been looking for and automatic manual valve body for my car but i dont think anyone makes one. only thing i can find is a full manual valve body. even TCI does not make one that i see. does any one know of one,
Old Oct 25, 2010 | 01:28 AM
Pro Built Automatics's Avatar
Re: shift kit ?
The TransGo Performance Shift kit is offered in "full manual" version if that is what you want. The TransGo Performance Shift that I offer will give you full automatic shifts and you will be able to hold any gear to any rpm if you want. With the full manual you still use the TV cable to control line pressure, so it is much easier on the front pump and sealing rings on the input shaft of the input drum. I have the modified version that allows smooth part throttle shifts and very quick WOT shifts in either version. The full manual does not cost any more than the full auyomatic version. Personally I would go with the full automatic version, as you will get tired of shifting it after awhile. Let me know if I can be of help? Dana
Old Oct 25, 2010 | 05:40 AM
Engine: 1999 LS1
Transmission: 4L60e
Re: shift kit ?
yeah i dont i dont want the full manual version since this is a street car. if you can give me a link to your web site ill take a look at what you have, thanks
Old Oct 25, 2010 | 09:36 AM
Re: shift kit ?
Go to https://www.700r4l60e.com/store/home.php?cat=65
Old Oct 25, 2010 | 09:46 PM
Engine: 1999 LS1
Transmission: 4L60e
Re: shift kit ?
what do you recomend for my tranny, i want a rebuild kit with a shift kit so it will shift right now when i tell it to and will hold up to 450-500 hp motor. do you have a part number you can give me that i can look at on your site. i got a 388 with edelbroke fuel injection on it. that is estimated power
Old Oct 26, 2010 | 06:29 AM
Re: shift kit ?
Go to https://www.700r4l60e.com/store/prod...&cat=19&page=1 This will give you what you need.
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
