shifter advice
Old Jul 28, 2010 | 03:03 PM
tjl IROC's Avatar
Car: too many
Engine: SBC
Transmission: AUTOs and a 5 speed :D
Axle/Gears: you name it
shifter advice
I just bought another camaro that has a 700r-4 with a manual valve body.
With the current shifter I keep missing gears (like jumping from first to third gear)
Does anyone know of a cheap shifter mod to make it harder to skip gears?
Has anyone ever seen a shifter that works like a manual with different positions for each gear but for an automatic?
Old Jul 28, 2010 | 03:10 PM
92droptopws6's Avatar
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
Re: shifter advice
B&M has a direct bolt-in model for your console called Megashifter it is a very good model with a small flaw the lockin pin does come loose a dab of loc-tite will solve that! 180.00
http://www.jegs.com/i/B-M/130/80692/...oductId=745759
my fav. shifter thats flawless
http://www.jegs.com/i/B-M/130/80701/...oductId=745761
Old Jul 28, 2010 | 03:20 PM
tjl IROC's Avatar
Car: too many
Engine: SBC
Re: shifter advice
I should have mentioned I use the car for autocross and need fast shifts up and down.
I have a BandM shifter and I find the pin a pain.(works for drag racing well)
I'm trying to find a shifter that the gears aren't in a straight line like a manual shifter.
I was also thinking of a paddle shifter but they don't look cheap.
Old Aug 5, 2010 | 11:37 AM
tjl IROC's Avatar
Car: too many
Engine: SBC
Re: shifter advice
Old Aug 27, 2010 | 11:02 PM
motleykent's Avatar
Car: 1987 Chevrolet Camaro Iroc-Z
Transmission: B&M 700R4
Re: shifter advice
You would probably like this shifter, if you can find one. I wouldn't mind getting one myself.
http://www.youtube.com/watch?v=jL55qonXZvs
https://www.thirdgen.org/forums/afte...ate-hurst.html
Old Aug 27, 2010 | 11:07 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: shifter advice
The Megashifter ratches up and down, doesn't it? Why is the pin a pain? How often do you need to shift into reverse when you autocross?
jaridjohn
Oct 5, 2015 07:01 AM
ndndndnd
Sep 28, 2015 08:00 AM
