Need some advice on BW 9 bolt rears
Old Jul 29, 2010 | 08:02 PM
mattkc's Avatar
Car: 1991 Camaro RS
Engine: 305tbi
I have finally got around to dropping my 10 bolt rear on my 1991 camaro RS and going to put a BW 9 bolt in. I have been reading a lot of info on the boards and found some great stuff. I was looking to see what gear set I had and it made me mad to see I had the 2.77 gears inside. So I would like to see what you guys think would be a good gear set for my car. It is a 305 V8 mostly stock I might drop a new engine one day another 305 or 350. I would like a little more power but something that could be driven on the street with no problem. I don't drive the car now just a hobby until I get it all fixed up. I would also like to take take it to the track once in awhile. Any help would be great.
Old Jul 29, 2010 | 09:14 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Need some advice on BW 9 bolt rears
3.45:1
Old Jul 29, 2010 | 09:47 PM
mattkc's Avatar
Car: 1991 Camaro RS
Engine: 305tbi
That was what I was thinking, but I saw I could get the 3.70 cheaper so I did not know what to buy. Do you know if you can buy the 3.45 gears or a 3 series carrier anywhere else other than 9bolt.com? Do I need to get the open carrier or the limited slip. Big price difference. One more question will I need to do to change or replace anything on the transmission?
Old Jul 30, 2010 | 04:56 PM
texascat2's Avatar
Car: 1989 Forumla 350 WS6
Engine: 5.7 TPI:Bosch III's 22#'s
Transmission: 700-R4
Axle/Gears: BW 9 Bolt Posi- 3:27
I have a question, why would you take a 10 bolt out to put a 9 bolt in? I can not find any parts for the Aussie BW diff. except in Australia! My local Diff shop doesn't work on them either.
Old Jul 30, 2010 | 10:31 PM
mattkc's Avatar
Car: 1991 Camaro RS
Engine: 305tbi
I like disc brakes and this has them on it already plus the 9 bolt is a little stronger. The 9 bolt came with the car when I got it but just not installed so I am going to try it out. If I do not like it I can work on the 10 bolt and switch back.
Old Jul 31, 2010 | 11:49 AM
texascat2's Avatar
The disc brakes all around are a lot better. I got concerned a few years ago when I thought the diff was not pulling from both tires. Started doing some research and could not find any 9 bolt parts except in Australia. My friend and I just flushed the tranny because it wouldn't shift correctly after many TV cable adjustments. Now it shifts like new. I resently replaced the injectors with FIC's Bosch III's 22#ers. Now it will idle smooth, starts easy and will spin the tires after shifting to second. My diff seems to be working fine, so I'm not as concerned about parts.
hectre13
Dec 11, 2023 08:14 AM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
sailtexas186548
Jan 19, 2016 12:21 PM
hectre13
Aug 26, 2015 08:17 AM
1nastygta
Aug 8, 2015 07:38 PM
