manual to auto swap this weekend
Old Jul 29, 2010 | 10:10 PM
ridingdead1984's Avatar
im swaping my t-5 for a th350 and wondering if im going to find any trouble spots along the way
Old Jul 30, 2010 | 12:35 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: manual to auto swap this weekend
You'll need the TH350 with the 9 in tailhousing, otherwise you'll need a different driveshaft.
You'll need the crossmember with the torque arm mount, or a tunnel mount for the torque arm.
You'll need an auto shifter and shifter cable, neutral safety switch, and you'll have to rewire your reverse lights, neutral safety, hatch release, etc.
You'll need a kickdown cable and the correct linkage for your carb setup.
I have no idea on the speedo.
That's what little bit I know about it from reading here. A will tell you more I'm sure.
Old Jul 30, 2010 | 06:09 AM
i have the 9'' tail shaft, spohn torque arm and crossmember, shifter neutral safety switch, and the reverse light, and the trans in a maunal valve body so dont need a kick down, the speedo was cable so that will work fro the th350 but only thing i dont get why wire the rear hatch?
Old Jul 30, 2010 | 11:00 AM
Car: 1992 RS
Engine: Carbed 350
The rear hatch is wired through the neutral safety switch on an automatic F-Body so that you cannot accidently 'pop' the rear hatch while the car is in gear. I mean you don't have to do it, it's just one of the wires I remember being on the neutral safety switch in stock form.
Old Jul 30, 2010 | 02:04 PM
i have a stick camaro so wouldnt i just have to wire it to the clutch switch?
Old Aug 1, 2010 | 01:33 PM
unezrdr_85's Avatar
Car: 85 Z/28
hi. im actually doing the opposite with my car. im switching to a manual. im having a hard time finding all the parts i need. im wondering if you'd sell ur old parts. lemme know. unezrdr_81@yahoo.com.
gta90
Sep 15, 2015 04:00 PM
mizz0313
Aug 12, 2015 06:45 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
rsrmoore
Aug 7, 2015 08:44 PM
