Swaping a 4 speed too 5 speed
Old Jul 30, 2010 | 09:32 AM
dougcj37's Avatar
Car: 82 Camaro Z28
Engine: 305 carb
Transmission: its stock
Axle/Gears: stock
Hey guys took my car to the shop to have the transmission worked on but it looks like its not worth salvaging...so I thought I would go ahead and put a 5 speed into the car. Its an 82 Camaro that has a 4 speed in it. My question is how much trouble iis this, will I need a new bell housing? will I need a different drive shaft length? will this be terrible? how many other parts wll I need?
Old Jul 30, 2010 | 10:49 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Swaping a 4 speed too 5 speed
You can keep your mechanical clutch release if you can find an '83 T5 bellhousing. Otherwise, just convert to hydraulic release by raiding a salvage yard. The hydraulics can come from a V6 car, they're the same as for the V8s. Then any '84-'92 305 T5 will work.
You don't need a T5-specific driveshaft, any '84-'92 version will fit.
The shifter from a V6 T5 will work, that also is the same as V8 versions.
Old Jul 30, 2010 | 04:56 PM
dougcj37's Avatar
Car: 82 Camaro Z28
Engine: 305 carb
Axle/Gears: stock
gotcha thank you so much....saw a kit from hawks for 1200 includes a transmission but sounded pricey to me hopefully I can find the bellhousing and and keep everything the same. Thanks again
Old Jul 30, 2010 | 05:46 PM
Guest
Guest
Posts: n/a
Mustang T5 shifters won't work because the F-car has the trans tilted 18 degrees
Elephantismo
Feb 13, 2019 12:51 AM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
RedLeader289
Sep 23, 2015 06:50 AM
john204481
Sep 7, 2015 03:22 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
