Swapping tailshaft housing on a T56, whats involved?
Old Jul 30, 2010 | 02:22 PM
tojan19's Avatar
Car: 85 Tojan
Engine: ZZ4
Axle/Gears: 9", 3.50
A few years ago I bought a T56 that had had weld repairs to the tailshaft housing. Well it still has a small leak at the flange and was pissing me off. Well last week I got a good deal on a brand new TS housing off ebay.
How much is involved in popping the old one off and installing the new one? I'm assuming there are some clearances I'll have to check? Is the bearing in the tail housing attached to the shaft or the housing? Any thing else?
Old Jul 30, 2010 | 02:38 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: Swapping tailshaft housing on a T56, whats involved?
The bearing is attached to the shaft. The shim is behind the race in the tailshaft. You would actually have to pull the trans out to check the clearance.
Old Jul 30, 2010 | 02:40 PM
tojan19's Avatar
Car: 85 Tojan
Engine: ZZ4
Not a big deal. I'll be pulling the engine anyway. Figured I'd have to pull the tranny to swap this.
Old Jul 30, 2010 | 02:47 PM
built91Z28's Avatar
To just swap it you would only have to remove the trans crossmember, the shifter, and the driveshaft. Its to check the clearance that you have to pull it. You will need a long piece of threaded rod that is 12x1.50 (I think this is the size). When you pull the trans you will see a pipe plug. Take this out and you can thread the rod into the 5/6 counter shaft and check for play. You will need some sort of dial indicator.
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
jharrison5
Aug 19, 2015 05:53 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
