Mini spool with 28 spline?
Old Jul 31, 2010 | 09:20 AM
89rs305-DP's Avatar
Car: 89 Camaro RS
Engine: Built 357 Vortec
Axle/Gears: 3.23 from an '87 iroc
So if i upgraded to these 28 spline axles ( http://www.summitracing.com/parts/SAG-EV10-4/ ) and ARP bolts, do you think it would be ok to run a mini spool? Would i have to buy a whole new carrier, or just the mini spool? It is driven on the street, with the occasional trip to the track. I have heard about how it will drive with a mini spool, and i dont really care, i just want to know that nothing is gonna break
Old Jul 31, 2010 | 11:37 AM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Axle/Gears: open/3.42
Re: Mini spool with 28 spline?
If I were you and just wanted traction to both wheels I would just get a spider gear replacement locker from Powertracks bcause the price for the axles and a mini spool would be about the same for the locker and since you don't see the track that often it would be a better buy for the money and better traction in all driving conditions . Just my $.02 . If you still want those axles and a mini spool that is fine but be careful when cornering . Have fun and be safe .
Old Jul 31, 2010 | 12:52 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Mini spools are never recommended for street or dragstrip use. They are not very strong. Mini spools are designed for dirt track racing or off road use.
Old Jul 31, 2010 | 12:54 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
I've done the "Lincoln Locker" ( welding the stock spiders, using a Lincoln brand welder ) with 26 spline axles and a strong 350. It was fine as long as I was running the 235/60R15 BFG Radial T/A tires, I ran it that way for months. But I killed it within 3 minutes of swapping on same-size M/T drag radials. Fortunately, within that time I ran a 10.21 at the quarter mile dragstrip. And it wasn't the welds that failed, nor the axles. It was the 7.625" Richmond ring gear.
The conversion style locker does cost 4 times as much, but is worth it.
Old Jul 31, 2010 | 02:10 PM
89rs305-DP's Avatar
Car: 89 Camaro RS
Yea i can either keep my 26 splines and get a powertrax locker, or i can go 28 spline with a mini spool. I dont really have enough to get 28s and a powertrax. How much stronger are 28s than 26s anyways?
Old Jul 31, 2010 | 03:39 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Your LO3 engine will never break a 26 spline axle, and sure doesn't need a mini-spool. I'd choose the PowerTrax.
Old Aug 2, 2010 | 10:52 AM
89rs305-DP's Avatar
Car: 89 Camaro RS
But thats the thing, within the next year i plan to do a 350 swap. Should make about 350 hp. So how much power can a 26 spline handle? I dont want to buy a powertrax for a 26 spline, only to have to upgrade to a 28 later
Old Aug 2, 2010 | 11:13 AM
89rs305-DP's Avatar
Car: 89 Camaro RS
And how do i know if i need a 7.625in or a 7.5in?
Old Aug 2, 2010 | 12:23 PM
AlkyIROC's Avatar
Car: 87 IROC L98
They're technically the same. Both gear sets will fit on the same carrier (posi.) It doesn't matter what you choose to use for an engine. If you plan on pushing the limits of the driveline, upgrade to aftermarket 28 spline axles. The ring and pinion will still be the weakest part of the diff. To put 28 spline axles in your diff, you'll need more than a 28 spline mini spool. The axles themselves won't fit through the hole in the side of the carrier. You'll need a 28 spline carrier.
If you break anything in the diff from abuse, your only other option will be to upgrade to something better such as a 9", 12 bolt or Dana 60. By the time you've beefed up that tiny 10 bolt, you could probably buy a 9" housing package.
Old Aug 2, 2010 | 02:20 PM
rustrider73's Avatar
Car: chevrolet
Engine: lots of em
as long as you are running street tires you should be fine w/26 spline powertrax or auburn unit but
if you plan on using sticky tires just kiss that camaro's *** goodbye now
Old Aug 2, 2010 | 03:54 PM
Rob's 92 gta's Avatar
Car: 92 firebird gta
Engine: L98 with minor mods.
I ran a mini spool in my 89 TA for a little while . My motor made 475 at the flywheel and it didn't break the mini spool. But I was careful off the line when I ran my slicks.
Old Aug 4, 2010 | 06:10 PM
Car: chevrolet
Engine: lots of em
Rob was the spool and axle's in that 89 28 spline and where did you get it
cheesehomer
Dec 31, 2015 08:48 AM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
darwinprice
17
Oct 11, 2015 11:51 PM
Numbah-1
Sep 20, 2015 09:31 AM
09ave
Sep 7, 2015 06:03 PM
