Drive or Overdrive?
Old Aug 2, 2010 | 06:27 PM
zwanboy104's Avatar
Car: 1986 Trans Am
Drive or Overdrive?
I just got a 1986 Trans Am and it's the first automatic car I've owned. With that being said, am I supposed to drive it in drive or overdrive? When exactly am I supposed to use overdrive?
I've noticed that when i drive the vehicle in drive, it seems to kinda stall sometimes between 60 and 80 mph. But if I put it in overdrive after, then off I go. My carb is pure junk. Could that have anything to do with it?
Old Aug 2, 2010 | 07:35 PM
slowmaro87's Avatar
Car: 1982 z28
Engine: 400
Axle/Gears: 3:23
Re: Drive or Overdrive?
yaa put the car in OD and go ...as far as fallin on its face you might wanna work on that carb ...more info on issue will help us out
GL
Old Aug 2, 2010 | 08:15 PM
zwanboy104's Avatar
Car: 1986 Trans Am
Thanks. That explains why it didn't seem to want to go faster than 60 or so. I didn't have it in overdrive!
Old Aug 6, 2010 | 11:45 AM
92Firebug's Avatar
Car: 1992 Pontiac Firebird Base
Engine: 305 TBI
Transmission: 700r4, B&M shifter & shift kit inst
Axle/Gears: 3:23....10 bolt
i have a 92 with a 305 tbi...and i prefer Drive....but in higher speeds OD really saves on the gas and engine wear
Old Aug 6, 2010 | 12:07 PM
'87IROCZOWNER69's Avatar
Car: 1987 IROC-Z and 1988 Iroc-Z
Engine: 5.7 350 V8 and 5.0 305 V8
Transmission: 700R4 Automatic Transmission
Axle/Gears: 3.27 Posi
If you are going to drive on the highway always throw it in OD your car runs at lower RPMs which means doesnt overheat as much and will save on gas and keep your engine from wearing down. I just use overdrive almost all the time it has just become second nature.
Old Aug 6, 2010 | 02:08 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Just leave it OD, anything under 40mph you are in 3rd. If you want to run at higher RPM.s drive 3rd all the time.
Old Aug 6, 2010 | 03:16 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I've hit 4th gear at as low as 28mph in my TBI car.
OD is the way to go. D (as well as 2 and 1) are provided for things such as towing - when on an uphill with alot of weight, alot of times the tranny will constantly switch between 4th and 3rd gear, making the drive a PITA. Also D, 2, 1 can be used as a brake of sorts - like down hill in the snow - you can slow your speed at the top of the slippery hill, drop to a lower gear, and the car will not gain as much speed going downhill as the engine is 'fighting' against the speed the car wants to go from gravity - better than applying brakes which tend to lock under slippery conditions and thus cause you to slide.
Vintageracer
Jan 10, 2020 05:33 PM
gta90
Sep 15, 2015 04:00 PM
86IROC112
Aug 21, 2015 12:39 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
