700r4 with non lock up converter.
Old Aug 5, 2010 | 05:25 PM
Project-RS's Avatar
i am in the middle of doing a carbed swapped 355. it originally had a tbi 305. i completely took out the ecu and only running safety controlled parts (headlights, blinkers, ect....). my question is, what do i need or dont need if im running a non lock up converter? do i need the 4 prong harness that runs to the transmission? do i need to by a tci lock up kit? should i buy a tci constant pressure valve body? any and all imput would be great. thanks.
Old Aug 7, 2010 | 12:20 PM
kd5icr's Avatar
Car: 1985 Camaro Z28
Engine: 305 mild build up
Axle/Gears: Stock
Re: 700r4 with non lock up converter.
Read this: https://www.thirdgen.org/forums/tran...run-700r4.html
Or go to the carb section and you will see a thread on TCC
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
HikoriYami
Sep 21, 2015 07:11 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
