speedo issue
Old Aug 3, 2010 | 03:25 PM
blackturbogta's Avatar
speedo issue
I'm new to the boards and any help would be great. Heres the issue I have an 89 gta that I am in the process of swaping to a t350 with 9 inch tail. I've been seaching the web and boards for the info on how to hook up the factory speedo but can't find a definate answer. I called dakota digital and the tech said none of the adapters they have will work. So I was wondering what everyone else has done.
Old Aug 4, 2010 | 09:50 AM
dellman83Z's Avatar
Car: 87 monte aerocoupe
Engine: 383 HSR w/ novi 2000
Transmission: Built 4l80e circle d converter
Axle/Gears: Currie 9" 3.89 gears
Re: speedo issue
Here's what I did. You will need these parts to get your speedo to work, http://www.summitracing.com/parts/DAK-SGI-5/ is the signal adapter. http://www.summitracing.com/parts/DAK-SEN-01-1/ is the signal generator and adapter to the trans. In the picture, its a cable like adapter, but its actually a solid metal piece instead. You could use a speedo cable from a 83 camaro that goes from the trans to the cruise control(like mine has) if you wanted. Just wire it up per instructions, drive and calibrate it and you're set.
Old Aug 4, 2010 | 12:17 PM
Re: speedo issue
I contacted jags that run and they are sending me a sender that is supposed to work but I'm a little sceptical since the sender doesn't seem to have the correct pulse signal. Also my cruise doesn't have a speedo cable atleast I didn't see one. I will keep everyone updated.
Old Aug 6, 2010 | 02:23 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: speedo issue
One way to do it is...
There's a 3" adapter block that lets you run a 6" tail TH350 or 700-R4 tailhousing on a 9" output shaft TH350.
I'm not sure which output shaft (700-R4?) has to be used so that the 700-R4 speedo drive gear lines up w/ the driven gear/VSS in the 700-R4 tailhousing.
But that would let you keep your speedo parts stock.
Old Aug 6, 2010 | 07:53 PM
Re: speedo issue
That would be a good way to solve the problem. Do you know who makes the adapter?
Old Aug 7, 2010 | 04:56 PM
jmd's Avatar
jmd
Re: speedo issue
http://www.teckpak-fitzall.com/dept.cfm?dpt=5&cat=21
I'm not sure which one is right for an F-body. But one of them is.
GTAman
Jul 3, 2024 07:29 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
andy74
Sep 3, 2015 08:41 AM
