disk rear end
Old Aug 14, 2010 | 12:21 AM
toolegit86's Avatar
Car: 83 camaro l69
Engine: turbo lsx
Transmission: th350
Axle/Gears: disk rear, 10bolt.
disk rear end
i am thinkin of picking up a disk rear end tomarrow. my question is what gear ratio is most common?? i currently have a 83 l69 with 3.73's but drums. the disk rear end is a posi unit out of a 90's gta and what is also needed to do the swap?
Old Aug 14, 2010 | 06:32 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: disk rear end
'87 GTAs all should have been built with 3.27:1. '88-'90 should be 3.27:1 or 2.77:1, unless fitted with the LB9 / T5 combo, then 3.45:1. '91-'92 should be 2.73:1 or 3.23:1, unless LB9 / T5, then 3.42:1.
Grab the proportioning valve and the e-brake cables if you can.
Also, grab the sway bars. They're better than what your '83 had.
Old Aug 14, 2010 | 11:29 AM
toolegit86's Avatar
Car: 83 camaro l69
Engine: turbo lsx
Transmission: th350
Re: disk rear end
ill see what i can find... i dont think it has the ebrake cables?
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
