Early 80's Impala Posi Rear End. Will it fit?
I have an open diff with 323's on my 85 z28. Have someone willing to trade me a posi out of an early 80's impala. 10 Bolt Drum with 373's. Will it fit?
Re: Early 80's Impala Posi Rear End. Will it fit?
The ONLY rear ends that will fit your car are 3rd and 4th gen F body rear ends. There are aftermarket 12 bolt and 9 inch Ford rear ends that will fit if you can afford them. NOTHING else will fit.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The early 80's Impala may have a 7.5" 10 bolt. Although the entire diff itself won't fit, you could pull the gears and posi out and put it into your diff. That is providing the Impala is a 7.5" 10 bolt.
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
hectre13
Aug 26, 2015 08:17 AM
