Need Recommendation on Quality Torque Converter
Old Aug 20, 2010 | 04:54 PM
86firebird350's Avatar
Car: 91 GTA
Axle/Gears: stock
Im getting ready to build my LT4 Hot Cammed 350 and put it in my 91 Firebird and im considering putting a small stall converter in with it but i dont know much about the brands out there. Ive been told by a few people to stay away from B&M all together. Can you guys recommend a good quality torque converter thats also not too hard on the wallet.
Old Aug 22, 2010 | 08:47 AM
Car: 91 GTA
Axle/Gears: stock
Re: Need Recommendation on Quality Torque Converter
bump
Old Aug 22, 2010 | 09:27 AM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
I don't know alot about the subject, but I have read in
mags like Super Chevy, Hot Rod, Rod Action, etc, that
a few things considered when looking for a torque converter
include from what I recall---
Axel ratio. Cam size { lift, duration, desired RPM }.
Desired performance. Lock-up or non-lock-up. More, but I can't recall.
By saying you want a " small " t'converter, do you mean
as in low RPM stall like around 2200-2400 RPM, or as in
8 inch, where the stall is higher around 3000 RPM?
Hughes has a good rep, but personaly don't know anyone using it.
Not much help I know. Maybe something in there you didn't
think about- IDK.
Good luck with your build!!
Old Aug 22, 2010 | 09:40 AM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Look into Circle D. There spendy but worth every penny...my 4c is 3800 and isn't bad at all.
Old Aug 22, 2010 | 10:10 AM
Car: 91 GTA
Axle/Gears: stock
think about- IDK.
ive a got a 3.42 rear gear and the hot cam has a 218/228 duration with 525 lift and 112LSA. i definitely want a lockup converter since i want to be capable of daily driver status...by small i meant somewhere around 2000 RPM. im not looking to go crazy on the stall speed. i just want something a little more than stock.
Old Aug 23, 2010 | 02:45 AM
Pro Built Automatics's Avatar
If you don't want to spend the money for the 9.5" Edge torque converter, ($545.00) then go with the Edge 12" 2,200 - 2,400 rpm stall. They come with a one year warranty, and go for $295.00. I have never had a comeback on his 12" units. Let me know if you need one?
88rscamar0
Sep 23, 2015 09:08 PM
Linson
Sep 21, 2015 01:08 PM
Nick McCardle
Sep 10, 2015 08:36 PM
89fast5oh
Sep 8, 2015 09:55 AM
