help wireing up my t-56
Old Aug 25, 2010 | 12:34 AM
COTY'S IROC-Z's Avatar
Car: IROC-Z
Engine: 350 VORTEC
Axle/Gears: 4.10
i done the automatic to t56 swop i need help wire up the reverse lockout i got the plugin for it.. but how do i wire it up.. an i got the reverse lights plugin how do i ware these up
Old Aug 26, 2010 | 12:22 PM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
Re: help wireing up my t-56
i dont use the reverse lockout i like it better that way and the reverse lights one is 12+ the other goes to the rear lights
Old Aug 26, 2010 | 01:17 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
For the reverse lockout, I wired it in with my brake lights. There are two wires coming out of the solenoid. One goes to ground, which I hooked up to the bolt the holds the solenoid on. Then the other wire just T's into your brake light wire coming out of the switch on the brake pedal.
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Hello, Michael
Aug 20, 2015 03:19 PM
cRoe4
Aug 7, 2015 08:46 PM
