torque arm bolts (need to remove trans..)
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Removing my transmission...and can't seem to get the damn torque arm off the tailshaft housing on the transmission, I loosened all the bolts but there is not enough clearance to pull it+the bolts off the tailshaft housing, and the one bolt holding the clamshell together is just going to round off if I keep trying to loosen it...and I don't have clearance to get one my stripped head sockets to it...need some help/advice here...
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: torque arm bolts (need to remove trans..)
can you unbolt it from the axle and remove it entirely?
Car: 1987 Trans Am
Engine: LQ9/L92
if you put a jack under the trans (with something to spread the weight), you should be able to undo the trans crossmember and slowly lower the rear of the trans until you have better access to the tailshaft
Engine: 3.8, 3.4
Nevermind... apparently the nut I was trying to turn is actually welded onto the bracket...had to turn the bolt from other side, now I just need to pull the TA out of the bushing without anymore creepyass spiders nearly falling on me...thanks though, chances are I'll run into more snags soon enough..
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Car: 1987 Trans Am
Engine: LQ9/L92
mine too. i've worked on it every couple days and every time i come back to it, there's a new web and occupant waiting for me....
Engine: 3.8, 3.4
Potato/pill bugs too...pulled one of my brake drums....whole bunch of them fell out...kinda disconcerting, make me wonder if they were eating the metal or something, and the other day I had bricks under the rear tires pulled one out, ton of potato bugs on it but it beats the hell out of ticks.....
ambainb
Apr 25, 2016 09:21 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
Dialed_In
Aug 20, 2015 01:45 PM
