car dies when shifted in to any gear. idles fine. seems electronic
Old Sep 5, 2010 | 05:43 PM
kylemeadus's Avatar
Car: 25th Anniversary Convertible Z28
Axle/Gears: Stock
i swaped trannys and now it dies when i put it in any gear wheither i give it gas or not. its as if the coil loses power. ive also tried it with the lock up wire plug off and it does the same thing. my idle is fine. any ideas?
Old Sep 5, 2010 | 06:28 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: car dies when shifted in to any gear. idles fine. seems electronic
Kinda sounds like the torque converter is staying locked
even with the plug off and is stalling the engine when
the tranny engages a gear-try it with the rear wheels
jacked up off the ground and see what happens...
Old Sep 9, 2010 | 02:20 PM
kylemeadus's Avatar
Axle/Gears: Stock
yeah i have the car on jack stands. the wheels will spin for a second. but then kaput
Old Sep 14, 2010 | 09:59 PM
92RS702's Avatar
Car: 92RS
Engine: 305= boat anchor
Axle/Gears: 4th gen 3.23
I had the exact same thing happend to my other camaro, turned out to be the converter. Have it looked at by some one who knows about transmissions they should be able to tell you if it's the converter.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
mizz0313
Aug 12, 2015 06:45 AM
