Difficulty engaging gears - Non WC T5
Old Sep 5, 2010 | 08:38 PM
Yor's Avatar
Yor
Car: 1984 15th Ann. T/A
Engine: 350 Goodwrench
Transmission: T5 (Not factory, possibly rebuilt)
For the life of me I cannot figure this issue out, and it was really bad today. I drove about 20 or so miles and was having a REALLY hard time shifting into gear, yet when I have the car turned off I can shift through all of them no problem. I replaced the fluid inside of it today before the trip, and notice my clutch fluid was about half-way low, so I topped it off. The problem has gotten really bad and am most likely not going to drive her until I can fix this issue. Does anyone happen to have any ideas? I've never had a problem like this with any manual transmission equipped cars I've owned (A 89 Z24 cavalier and a 90's cavalier I drove for a while while a friend was away).
Old Sep 5, 2010 | 09:23 PM
Yor's Avatar
Yor
Re: Difficulty engaging gears - Non WC T5
Gah, even more ridiculousness! I let my car sit for a few hours today when I got home, just went out, started it up and was able to shift through all gears with no effort at all. Then I went and checked it this morning and it was difficult for a moment, then almost completely fine. -sigh- So confusing.
Old Sep 6, 2010 | 07:04 PM
Yor's Avatar
Yor
Have been looking around under my car and near my clutch pedal and noticed the clutch master cylinder was leaking a bit of fluid. The slave cylinder also had some clutch fluid as well, so I've begun taking the hydraulic clutch system out of the T/A. So far I have the brake booster nuts and the master cylinder nuts out, have unbolted the reservoir, pulled the brake booster forward about an inch and gotten the master cylinder loose from the cowl. Tomorrow after work I will be walking to Autozone and picking up a new master clutch for about 60 or so, and the slave cylinder for about the same price.
Once I replace these two, are there any other major parts to this process I should know of other than installing everything properly? the system still has clutch fluid in it, when I replace the two cylinders is there any specific process needed to add any more fluid to the system?
Thanks.
Old Sep 6, 2010 | 08:49 PM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
Definitely sounds like either the master or slave cylinder. Either is fairly easy to replace - The slave is by far the easier tho - You pretty much replaced them - In the past I've found it easier to remove both together so that you can tap the line retainer pins out with something like a small punch or drillbit.
As for when you have everything replaced, just put fluid in it (I'd put a little bit of fluid in both the slave and master and push the pistons in to get fluid moving inside before I mounted them) it SHOULD automatically bleed with just some clutch pedal compressions.
FYI - If you have an AdvanceAutoParts near you; I just got my brand new master cylinder for $39! I bought it online and then picked it up in the store. Used coupon code "A123" and it saved me $20! I used it just this past Saturday. I think if you buy the master at one store and the slave at another, you'll save $20 on both if you do 2 separate purchases.
Old Sep 6, 2010 | 09:03 PM
Yor's Avatar
Yor
Yeah, I've never done either of these before but I know my way around a car decently, not an expert but not a noob. They both seem somewhat old and leak a little bit, as my clutch reservoir was about 1/4 of the way from full. And yeah, when I jacked up the car the first time (I was just looking to see if anything just stuck out, out of the ordinary) I looked in my Hayne's Manual (Yeah I know, they usually suck but this one has treated me well so far) and I spotted the slave cylinder behind the heatshield, and I noticed the slave was a little wet, not much but a bit.
Theres an Advance Auto about 10 miles away, however my car is in pieces right now and currently my only vehicle. D'oh! lol. thankfully I live 1/2 an hour away from work, and Autozone is about the same distance. So is a VIP and NAPA, but I hate those guys, they're clowns.
As for the new fluid, I'll be sure to do that, thank you for the heads up. I'll buy a decent sized bottle of DOT3 so I have some extra just in case. I REALLY hope this will solve my issue, as the Transmission was only put in back in '01, and I'm hoping the guy put one in that was at the very least rebuilt (It's painted all blue, not sure why.)
either way, if this doesn't solve it then I will go and replace the clutch (I REALLY doubt that's what it is, since when it gets into gear it moves perfectly fine, doesn't slip or anything).
Old Sep 6, 2010 | 09:14 PM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
Still sounds like you need to get a ride to Advance - Save yourself up to $40! I looked for coupon codes for Autozone and found nothing really except for free shipping....
You won't need a whole lot of fluid, the small bottle will probably work just fine. As for the clutch, I highly doubt that's your problem - From the sounds of your 'wet' master/slave setup, that's most likely your problem - If the clutch can't disengage completely from the engine, you're not going to be able to shift all that well. Plus, the inconsistency of when it's happening points to the system bleeding itself, getting better, and then the fluid level dropping, resulting in the hard shifting because the clutch isn't fully releasing.
Old Sep 6, 2010 | 09:26 PM
Yor's Avatar
Yor
Very good points. I'll try to get a ride, though the chance it slim, simply because of my days off being mid-week. I'd like to save a little cash, but for the sake of the car I can let the wallet thin a little. She misses being on the road already. lol.
Alright, I'll buy a regular sized one then, as my little bottle is nearly empty. And yeah, I really didn't think it was the clutch either, since when it does engage it goes very nicely.
Thanks a ton for the pointers Dante, I really appreciate them. I'll be posting on my progress as it comes. Not much will occur tomorrow since I work 8-6, mainly just me buying the equipment I'll need.
Old Sep 7, 2010 | 07:51 PM
Yor's Avatar
Yor
So I got my master and slave cylinders out of the T/A today, and got my replacement ones. However, I am having a bit of difficulty taking the hydraulic line from the old master to slave. I will be posting pictures in a moment of what I'm talking about, but since I did not buy a new line I am trying to see if this one can be removed and reused for my new master and slave cylinders.
I also got a picture of the leaking master cylinder from before I took it out, as well as a picture of the full assembly I removed.
Old Sep 7, 2010 | 07:54 PM
Yor's Avatar
Yor
http://i74.photobucket.com/albums/i2...-06-54_365.jpg this is the old master cylinder I removed. As you can see, right where the boot is, it had been leaking quite a bit every time I pressed the clutch pedal.
http://i74.photobucket.com/albums/i2...-16-45_815.jpg
This is the entire old assembly with my new master and slave cylinders
http://i74.photobucket.com/albums/i2...-40-31_601.jpg
This is one side of the hydraulic line that just doesn't want to come out, and I would rather not force it since I'm sure there's a way for it to be removed, as the master cylinder spins in place around the line.
http://i74.photobucket.com/albums/i2...-41-14_742.jpg
Other side of said line, spins in place as well. I'm assuming that the small holes on each side of the cylinder are how you take the line out, but I am not positive. Any help would be appreciated.
Old Sep 7, 2010 | 07:55 PM
9manastacio's Avatar
Car: 98 camaro ss, 98 grand cherokee 5sp
Engine: 5.7 ls1, 4.0 sixxer
Transmission: T56, ax15 swapped
Axle/Gears: 3.42, 3.73
other things to consider, make sure you bleed the hydraulics properly, and i had the exact same symptoms a few months after installing a new clutch kit on my old v6. It would shift fine sometimes, other times it wouldnt want to shift at all. I found out the pilot bearing was gone, and the pressure plate fingers were bent, preventing full disengagment. Another thing, make sure all bellhousing to engine and trans to bellhousing bolts are tight ight tight!!
Old Sep 7, 2010 | 07:58 PM
you remove the line by taking something like a small punch or screwdriver, and punching out the pins on the master and slave. be careful not to damage the plastic line, and make sure if you dont have new pins, to save the old ones
Old Sep 7, 2010 | 08:02 PM
Yor's Avatar
Yor
Well I very much hope it isn't anything terrible. I mean replacing a clutch isn't that hard, but I don't exactly have the time at this point to do so, and this is my daily driver for the rest of the fall.
As for bleeding the hydraulic system, how would I go about that? I see there is a bleeder screw on the slave, would I simply add fluid to the system, press the clutch pedal and loosen the bleeder, then tighten it back up and repeat the process? I assume as much since that's how brake bleeding works.
Old Sep 7, 2010 | 08:06 PM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
If you didn't already figure it out, the small holes on the cylinders where the lines attach have a retaining pin that needs to be removed - Its very easy, if you don't have a small enough punch, a tiny drill bit will work to use a punch.
As for bleeding, AFAIK, all you do is put fluid in and then pressurize the system by pumping the pedal - Its a self bleeding system. I would recommend putting some fluid in both cylinders and pumping them manual before installing them, just to get some fluid into them so they're not dry right off the bat.
Old Sep 7, 2010 | 08:09 PM
Yor's Avatar
Yor
Doing it right now, actually. Just got to grab one of my smaller screw drivers to see if I can get them out without too much harm.
I also bought an extra little container of fluid, so I should have plenty to fill these up and pump 'em a few times before putting it all together. Like I said, I'm going to try and throw this all in the T/A tomorrow morning and see if I can have it shifting well before the end of the day. That will give me all of thursday to check for any issues and whatnot I may have.
Thanks again for the help Dante. I was wondering, did you finish your T5 swap, hence why you know about the bleeding and setup for all this? Just curious.
Old Sep 7, 2010 | 08:20 PM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
No prob - I ran into some other snags on my T5 swap - My fill plug on the side is completely stripped and nothing seems to work to get it out; I've tried literally everything I can think off - even broke off an easy out inside it...
As for the clutch bleed; I remember reading it somewhere; plus its worked that way on every 5spd GM cars I've ever had.
Old Sep 7, 2010 | 08:33 PM
Yor's Avatar
Yor
Hmmm, I see. That's why I LOVE the aftermarket plugs that have a box wrench fitting on the outside of it, impossible to wreck one of those. xD
But as for that plug. hm. I work at a quicklube, so I don't have a ton of mechanical experience, but when it comes to drain and fill plugs I can usually manage to get most any one of them out. If you can take a picture of it some time I could prolly throw some ideas out there for you, since you've helped me and all.
Old Sep 7, 2010 | 08:34 PM
Yor's Avatar
Yor
Oh and, I used a small screwdriver as a punch and now have both the retainers out and the line. As for putting fluid in them, should I put fluid in them prior to installing the lines or after I do so it won't leak out anywhere. Just curious.
Old Sep 7, 2010 | 09:18 PM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
I "primed" mine just by adding a little fluid and then pumping them manually; off the car. I don't know if its 100% needed, but it makes me happier to know that both cylinders are ready to go - of course they'll still have some air in 'em, but at least you'll not have to pump the pedal as much as if they were dry; plus you'll know whether or not they work prior to installing them.
Old Sep 7, 2010 | 09:20 PM
Yor's Avatar
Yor
Oh, I just realized. One thing about the priming them thing, if you prime them won't the plastic strap on the slave cylinder break open and make installation a bit more of a pain?
Old Sep 8, 2010 | 06:21 AM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
Shouldn't make much difference - It's really no different than if you had to do a clutch job; the strap would already be missing.
Old Sep 8, 2010 | 09:02 AM
Yor's Avatar
Yor
Good point. xD Thanks again man, I just got up and throwing both of them in in a little, hopefully this will solve my issue.
Old Sep 8, 2010 | 03:00 PM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
Let us know how it goes.
Old Sep 8, 2010 | 03:51 PM
Yor's Avatar
Yor
Dang you have good timing Dante. Lol
FINALLY got the master and slave in- ran into a setback when I realized the new master and slave didn't come with o-rings so I had to take it all apart andget the old ones that I threw out (had to go dumpster diving, ugh).
HOWEVER, once I did that and bled out about 16 fluid ounces of brake fluid (the slave had a bleeder, so I went ahead and just used it since it seemed like a good idea), threw it all in and fired it up-
She shifts WONDEROUSLY. I can literally shift through ALL gears with my thumb and index finger, and I no longer get any grinding when I go for reverse.
Thanks a ton for the help guys, hopefully this thread will prove useful to someone else who has to do this work on their car. It's WELL worth it if you're having the same issues I did, the T/A has never shifted better.
Old Sep 8, 2010 | 03:54 PM
Yor's Avatar
Yor
As a side note. When I was bleeding out my slave cylinder, I noticed a VERY large bolt on the side of my bellhousing closest to the heatshield and clutch-fork. It was out like half way from where it should have been, so I tightening that back up. I pulled the boot back from where the clutchfork exits the bellhousing and I noticed a small shaft that was on the opposite end of this bolt, and it meeted with these small tabs on the clutch fork. Not entirely sure what it does, but it was sticking halfway undone out the back of the bellhousing, so I tightening it up a bit. xD
Old Sep 8, 2010 | 04:25 PM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
That was/is probably your pivot bolt for your clutch fork. Its what the fork pivots on when you push the clutch pedal.
Glad everything worked out for you - glad we could be of service.
Old Sep 8, 2010 | 11:38 PM
lunaticinaZ's Avatar
Car: 1991 Black Z28 G92
Engine: 350 for now
Transmission: wc t5
Axle/Gears: factory 3:42
wow the search button really worked this time ) my car is doing the same thing and now I know what to look for. but one question for you guys. the cap on the reservoir is cracked around the side between the threads. I know brake fluid attracts moisture. could the crack in the cap eventually cause a problem?
Old Sep 9, 2010 | 06:47 AM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
Yeah it could - I'd just hunt around for a cap in the junkyards - I have an extra reservoir but the cap on it is cracked too.
You might be able to epoxy it together to seal it.
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
dbrochard
Sep 7, 2015 09:41 AM
Glowsock
Sep 6, 2015 06:40 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
