HELP!! Drove to the track, had to trailer home
Car: 1982 Camaro Coupe, 2004 Grand Prix
Engine: 6.0 iron block LS, series III 3.8
Transmission: T56, 4T65-E
Axle/Gears: 3.42s<--hate em...need some 4.30s
ok so last night i took my car down to the nearest strip and thought i'd run it down the quarter a few times, well on my 1st run, the burnout went good, stage up, green, go!!! i pulled hard and when i shifted 2nd and dumped the clutch there was a loud pop and some racket that seemed to come from my trans (t56), lost all gears, nothing catches, driveshaft doesn't turn and there is alot of noise coming from the bellhousing. Did my clutch come apart? TOB failure? It makes hella noise at idle and the shifter vibrates pretty good. Using a spec 3+, sucks had to trailer it home, got back around 5 a.m. <----RETARDED Any ideas appreciated
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: HELP!! Drove to the track, had to trailer home
Apparently something broke. The only way you're going to know what it was is to pull the tranny and have a look.
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Yep, got to pull it. BTW, if your not running slicks, your better off doing no burnout. Just drive around the water box.
Thanks for the advice!! Well I gotta work on gettin my buddys shop cleaned up so maybe i can drop it in the next few, just hope its not my trans!! Hopefully i'm just another dude with a exploded SPEC clutch!! F**KIN $600 POS
Well i got a little anxious and thought i'd pull my slave off and check it out with a bore scope, when i pulled it off a few little pieces of clutch fell out and its all covered in black dust inside.................anybody wanna point me in the direction of a good clutch manufactuer??
For some reason a ton of people seem to have problems with aftermarket performance clutches. It seems like people have better luck with generic parts store replacements then some of the popular aftermarket upgrades. If I felt I needed something better then stock, I'd look to http://www.clutchnet.com/ Not that I've got one of their clutches behind a T56, but I've had one of their clutches before and was impressed with it.
tyeo098
Nov 30, 2015 06:27 PM
