View Poll Results: What should i do with my rear end?
Find new/used Auburn unit and have gears installed at time posi unit is replaced.
0%
Find a Zexel Torsen unit and have gears installed.
100.00%
Find another 4th gen rear with better gears.
0%
Find another 4th gen rear and have gears i want installed.
0%
Voters: 1. You may not vote on this poll
4th gen rear end issues....
Old Sep 14, 2010 | 08:32 PM
v10viper04's Avatar
Car: 84' Corvette, 96' Caprice
Engine: LT1, L99
Transmission: T-56, 4L60e
Axle/Gears: 3.07 POSI, 2.93 Open
Yes i have tried searching and i couldn't find what i was looking for.... Ok so i have a 4th gen rear in my car. It has 3.23 gears and its LS. MY problem is that she will only spin 2 wheels when I'm going straight and at the track i get a 50/50% chance that both will spin on launch.. The rear is out of a 95' Z28 (or so i was told) if i turn right or left and pin it i get a nasty one wheel peel.. which i'm NOT a fan of. I was told the 4th gens use Zexel Torsen units which don't need servicing or very rarely do. I shouldn't have an Auburn unit should I? (it deff IS a 4th gen rear, its 2" wider than my old one) I feel like i do b/c i can see springs in the POSI unit. The Zexel Torsen units don't have springs right? If i do have an Auburn unit what are my options? I would like to upgrade to 4.10's or 3.73's too at least...(attached picture is not MY unit but a unit that looks identical.) Thanks
Old Sep 14, 2010 | 08:43 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 4th gen rear end issues....
Auburn, 93-97
Zexel, 98+
Pics of the Auburn in the following link:
https://www.thirdgen.org/forums/tran...ing-axles.html
JamesC
Old Sep 14, 2010 | 10:54 PM
Drew's Avatar
Sure looks like an Auburn to me. It's probably well worn/worn out. I can't really give you any advice on how to rectify the problem short of replace it with a new one, or upgrade to a better carrier.
Edit: Where's the option to buy a new (not used) limited slip carrier, and install gears? Used crap is used crap, if you're going to spend money installing gears, do it once, do it right, and never worry about it again.
Old Sep 15, 2010 | 03:20 PM
v10viper04's Avatar
Engine: LT1, L99
Well i don't want to dump money into the 10 bolt. I don't want a rear i might break. I'll dump money into a 9" or 12 bolt but not a 10 bolt. I just was hoping to find a rear for sale with a good working posi and good gears already installed. But i don't get that lucky. haha
1992rs/ss
Jan 31, 2025 05:10 PM
hectre13
Dec 11, 2023 08:14 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
AkDrifted
Aug 17, 2015 07:45 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
