10 bolt ID problem
Old Sep 15, 2010 | 06:35 PM
pimpimusmaximus's Avatar
Car: 1984 Z28 T-TOP
Engine: 355 Lt1 w/Hotcam
Transmission: TH700R4
Axle/Gears: 3.73 4th gen limited slip
10 bolt ID problem
I have an 84 Z28. Rearend ID begins with 6HF. I looked and it says its from an 89 w/3.08 posi. Ok, weird but understandeable. Then I free spun the tires, they turned opposite directions. Dosen't that mean it's not a posi? The haynes manual dosen't list this end in 84.
What is it? Is it a posi? Is it a 3.08?
Old Sep 15, 2010 | 07:11 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 10 bolt ID problem
Dump the cover--the fluid probably needs to be changed anyway--and take a peek. The following FAQ discusses gearing and limited slip:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Sep 15, 2010 | 07:46 PM
big gear head's Avatar
These rear ends had the Auburn and the Governor Lock in them. If you have the Governor Lock then you either didn't spin it fast enough to cause thee governor to lock, or it's broke. If you have the Auburn then it's just palin worn out and must be replaced. You can not rebuild the Auburn, and I wouldn't even try if you could. They are junk.
The ONLY way you are going to know what you have is to remove the cover and look at it.
Old Sep 16, 2010 | 02:26 PM
Car: 1984 Z28 T-TOP
Does this mean that my rearend is from another vehicle? Is the Haynes manual incomplete?
Old Sep 16, 2010 | 04:34 PM
No, the Governor Lock and the Auburn were both factory installed differentials in these cars. You are going to have to remove the cover and see what is in it.
Glowsock
Jul 24, 2025 03:15 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
theurge
Aug 21, 2015 12:46 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
